02-17-2014, 08:30 AM   #1
cali92rs's Avatar
Bands in my scanned negative
I've noticed vertical bands when i scanned some negatives on my friends plustek 7200.
See below, about a third from the right side of the image.
What causes that? I dont see anything on the negative itself.
Thanks in advance
02-17-2014, 08:47 AM   #2
There seems to be some discoloration on it too, so it might actually be the film. Try flipping it around in your scanned and see if the band gets flipped as well- that should help us identify the culprit
02-17-2014, 12:07 PM   #3
Are you scanning BW film in color mode? Why is it green in the middle. Try converting it to a grayscale and see if you notice the bands.
02-17-2014, 12:17 PM   #4
Otis Memorial Pentaxian
I have seen similar bands with my Nikon Coolscan scanner. On that unit they seem to be related to edge of the scan frame vs. edge of the image frame.
02-19-2014, 07:27 AM   #5
G and T's Avatar
My dedicated 35mm scanner is a Canoscan FS 4000 US and because of its lack of,or insufficient shielding, I get similar bands if it is operated
too close to any source of electro-magnetic radiation. This was a well known and well documented fact with this scanner. When I'm scanning
with it I just move it well away from any speakers, printers,scanners, monitors or other computer peripherals and the problem disappears.
Your scanner could be having a similar issue.
Glenn
02-19-2014, 07:38 AM   #6
fretlessdavis's Avatar
QuoteOriginally posted by G and T Quote
Glenn
Never thought of that! I guess having my 4490 sitting on the desk next to my bottom mounted 850w power supply for my PC could be the culprit.... good to know that it may not be broken!
02-19-2014, 03:59 PM   #7
Glenn
Thanks for posting this.
bands, film, photography
Wow. My first negative experience in a photography course frogoutofwater Photographic Technique 21 01-14-2014 05:41 AM
PPG Upload can't read EXIF from scanned Negative? arbib General Talk 4 02-21-2011 08:25 PM
Scanned B/W negative sat high resolution kjfishman Digital Processing, Software, and Printing 3 02-16-2011 06:49 PM
blue bands in my IR OmegaKulu Troubleshooting and Beginner Help 2 01-03-2011 05:17 PM
Light/Dark Bands in Film k0og Film Processing, Scanning, and Darkroom 11 01-18-2010 03:36 AM
All times are GMT -7. The time now is 03:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
