I would like to disassemble this old Beseler 75mm 3.5 enlarger lens. There is absolutely no obvious way to take the thing apart for servicing. Does anybody have any ideas on how to do this?
No hint of screws or other apparatus that holds the thing together. A friend of mind who works at a place doing lens and camera repairs suggested the beauty ring (the front surface with the name and serial number on it) might hide screws in a fashion similar to Canon lenses. However, there is no obvious way to remove that surface. The rear element has a thick metal ring around it, and it appears the ring might be threaded onto the assembly. However, the ring does not budge for any amount of force applied to it. I've tried using a rubber band to improve gripping power with no success. I, nor my friend, have any kind of tool that would fit in the gap between the ring and the outer part of the lens barrel. I suspect the ring may be held in place with some kind of glue like Loctite. There is a seam where the aperture ring meets the other half of the lens body, however exerting force here would very likely break the aperture mechanism and have nothing to with opening the lens. I have searched every resource I can think of and can't find any reference to servicing this thing.
I'm hoping to sell the lens along with its matching enlarger. I expect somebody will pick up the enlarger more readily if they don't have to worry about picking up a lens to go with it. The problem is the aperture blades are oily and some of the lubricant has atomized onto the inner surfaces of the elements. I'm willing to at least try cleaning the thing; this kind of enlarger lens has a very simple optical formula. I think it's only three elements.
Any suggestions would be appreciated!
