Originally posted by artobest Only initially; if I read your original post correctly, you tinker with the black point later. Histograms in scanner software are quite imprecise - I think it's safest to back off your black point and set it properly later, when you have better tools to evaluate it.
I did tinker with the black point later, but also explained that I move the black triangle back to where it was before.
Yesterday, I played around with using the method that you recommended, and it definitely has it's merits. I had a tough time with getting good color balance after inverting though, but I imagine practice would help.
Also after all said and done, I couldn't see any real significant improvement one the final image, compared to the same image scanned my normal way.
Scanning as a positive has the benefit of being able to return to an unadulterated source file and re-processing, without rescanning, if you're unhappy with your initial results.
Here are my best efforts using each method.
