It is interesting to see new colour film scanners coming while the range of available films is decreasing.
One issue (I have the PrimeFilmPro120) is with film grain on c41.
I read that C41 dye clouds are typically stochastic in range 1.5 ~10 um or so.
That is 16000 to 2500 pixels per inch.
So if the scanner is in this range we have the possibility of amplifying the grain into clumps randomly in the image by aliasing (interfering sidebands),
according to Messrs Nyquist and Shannon.
I think, not sure, I have this problem in blue sky on the 35mm Fuji Superia iso 800.
https://app.box.com/s/omlyj78yl9m884dq7kdv
Maybe it is better to reduce the scanner DPI to 1800 or so when scanning C41 35mm ?
I am also trying to expose C41 iso 800 at EI200~640 to see if it improves.
