Originally posted by theSixtyEight Hey guys, I just started to do some film photography and I have this problem shown on picture. Either my frames come out complete dark or complete transparent,
Could oyu please explain to me whats the cause of this? Light leaks, bad shutter, or both?
Thank you!
The ones that appear dark on the negative are over exposed. They have received too much light.
The ones that appear light on the negative are under exposed. They have received too little light.
The fact that the ones that are either too dark or too light show no other details indicates that they are grossly over or under exposed.
Try using the ME Super on Auto and see what the shutter speed is. Then switch to Manual, leave the aperture on the lens the same, and adjust the up and down buttons till neither the over nor under light are lit. The shutter speed value should be the same.
If not, there may be problem with the Auto exposure system.
Also try using the camera on manual to see how the exposures come out.
Also listen to the sound of the shutter. Listen to whether it is sounding too long or too short relative to the indicated shutter speed.
Regards
Chris
