...the worst in this case being that I must have not quite had the MX's sprocket release button pushed down hard enough, and I consequently pulled the film off the canister spool when trying to wind off.
THE GOOD NEWS... I have a darkbag and a full B&W processing kit.
THE BAD NEWS... it's colour film and I can't get hold of the chemicals to process it at home (not even a C41 press kit), or I'd just put it straight into the patterson tank and rock on.
SO, how do I proceed from here? If worse came to worst I could sacrifice the film, but I would prefer not to. The best solution is one that gets it back into the cannister to send off for regular processing. The second best is a recipe to home bake C41 in black and white chemistry. I'm shooting Fuji 400 and my chemistry is Kodak D76 and Kodak fixer (which I had bought for use with Tmax).
My first impression is to dismantle the cannister, stick the film back on the spool with sticky tape, reassemble and carefully wind it back. A desperate solution, true, but better than nothing.
---------- Post added 13-03-16 at 15:40 ----------
Update - I managed, by means of ungentle manhandling, to coax about half of it back into the cannister. That was the point at which I cut my losses. I tried opening the cannister destructively without any success.
UPSIDE: I have a short length of film with which to practice loading the Patterson tank.
