10-25-2016, 09:58 AM   #1
Bad scan or bad exposure? Scanning aerial shot of ice
I am working on scanning a two year backlog of Velvia 50 I've shot and all was well, till I hit a challenging roll - aerial shots of ice sheets. I remember the ice being more glistening and the water a little darker - and couldn't mount my polarizer (filter ring v slipstream) but these shots look especially flat. Since I haven't scanned in a long while, does this appear to be a shot where I screwed up the exposure not accounting for ice reflectivity, or is this the scanner exposing poorly?
I used the DiMage's autoexpose on one shot and then shut it off in another and they seem to be close enough to suggest it was my exposure and that I should chug along and try to salvage in post-processing. (I think I corrected for this later on but only halfway through the roll )
10-25-2016, 10:27 AM   #2
Otis Memorial Pentaxian
Your original slides should be your guide. If you have access to a light table and loupe, direct examination should indicate the amount of highlight detail as well as color balance/intensity. Tweaking the scanner to capture the nuance of the original may be difficult, but should be attainable.
10-25-2016, 10:41 AM   #3
Alex645's Avatar
Agreed with Steve. Are you using VueScan with the DiMage Scanner? I've often found that the profiles for specific films like Fujifilm Velvia scans worse than if I just use the Generic profile and then do PP in PS. Are these aerials 35mm, 645 or 67?
10-25-2016, 10:59 AM   #4
35mm Velvia, scanned with the DiMage Scan Utility (never got Vuescan). I've always wanted to do the most basic scan, archive the film and then play in photoshop, so I did just use default profile, 16 bit, autofocus/expose. From Haleakala to the Grand Canyon this usually works fairly well but the ice trips me up
Thanks for the replies.
10-25-2016, 12:23 PM   #5
Alex645's Avatar
Yes, too bad you couldn't get the polarizer on. I think it is the exposure and I suspect a ton of UV that affected the exposure. Do you completely trust the lab that processed this? E-6 processing takes much more precision and especially ISO 50 with its very small exposure latitude. I usually bracket a lot with 50 and 100 ISO reversal films.
exposure, film, ice, photography, roll, shot, shots
Bad camera or bad cards iClick Troubleshooting and Beginner Help 5 09-15-2014 11:33 AM
Lens Rentals - Bad Times with Bad Filters interested_observer Pentax SLR Lens Discussion 5 10-23-2013 01:08 PM
Bad lens or bad polerizer TRAINUT Pentax Camera and Field Accessories 3 04-30-2012 12:43 PM
FA 31mm Limited assembled in Vietnam - bad QC or bad luck. Voe Pentax SLR Lens Discussion 64 03-03-2010 05:44 PM
Tamron Adaptall... Bad lens or bad adapter Okami Pentax SLR Lens Discussion 6 05-01-2008 06:52 PM
All times are GMT -7. The time now is 08:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
