Originally posted by BigDave You are concerned about UNDER fixing after fixing for ten minutes with the powdered fixer, yes?. I believe this is Kodak Rapid fixer, but I could be wrong. Once the film hits the fixer, after about 10 second you can expose it to light briefly. The rule of thumb I always heard was you fix twice as long as it takes to clear the film. I would fix for about tem minutes and I still have negatives that show NO sign of deterioration. Unfixed or under fixed film will have a whitish/grayish coating to it. This is the unexposed emulsion before it is removed by the fixer. If you look at the film at this point (usually still on the developing real) you can probably see the darks and lights of images on the first few frames. When you cannot see this anymore, the film is cleared. With fresh rapid fix this usually takes from three to five minutes. Double that time (6 to 10 minutes) and you are good to go. Wash, Hypo Clear, wash again, photoflow and hang to dry.
If you are fixing for 10 minutes and the film is clear, you are very probably fine. I think you are over-worrying about this one.
Regards,
Thank you. I gather that what you mean by "when you cannot see this anymore" is the whitish-greyish coating - it makes no sense for it to mean the images!!!
I have heard of a trick whereby you take the exposed (ruined) leader (which you clipped off before spooling the film) and throw that in the fixer - when it turns from dead black to clear, take that time and double it and that is your safe fixing time. And when that half life doubles from what it originally was, the fixer is spent and needs to be ditched. Does this make sense?
