Originally posted by lithedreamer That's good info, thanks. The chemicals came with instructions, but nothing this detailed. I don't do inversion agitation, do you know how that translates to 'stir agitation'?
For years I used the Paterson agitation stick to slowly rotate the reel in the tank about 10 seconds per minute, but I may have found if you donʻt rotate/spin the reel at just the right speed, I was getting what Tuco mentions as laminar flow.
Ever since Iʻve been using inversion agitation which is more similar to what is done with metal developing tanks. After adding the solution, Iʻll knock the bottom of the tank a couple times to release any air bells, then with the Paterson tank stir for 10 seconds then cover everything with the lid. Every 60 seconds I invert the tank twice for the remaining development or fix time. In lieu of stirring with the agitator, you can do the inversion with a twisting figure 8 type motion. Keeps your wrists limber and makes the time pass better with the right music.
