01-02-2017, 04:57 PM   #1
Pentax Auto Bellows A with Slide Copier A - Question
Hi there,
My Dad had an old ME Super that he used for copying slides on a Pentax Auto Bellows A with Slide Copier A. Later on he switched to a K100D Super. Most of the slides he did, I believe were done using the K100D.
The Pentax Auto Bellows A allows the ME Super to attach with no problems; but doesn't seem to attach to the K100D.
What I'd like to do is attach a Canon DSLR to the Pentax Auto Bellows A with a k mount to EOS adapter. (I have several of the old k mount lenses that I use on my Canon) The problem with my 7D Mark II as well is that the camera won't fit onto the mount due to the section of the bellows that sticks out at the base, where it attaches to the lens. (has the Pentax Auto Bellows A sticker on the attached photo)
Any suggestions on a mount extender of sorts, for attaching a body that won't quite turn into place?
Thanks!
01-02-2017, 05:26 PM - 1 Like   #2
jatrax's Avatar
Extension tube?
01-02-2017, 05:34 PM   #3
Fair enough, didn't think of that!
Thank you!
01-02-2017, 05:39 PM - 1 Like   #4
baro-nite's Avatar
Remove the camera-facing mounting ring from the bellows (easy, just loosen the set screw) and mount it to the camera. Then you can re-attach camera and mount to the bellows without rotation.
01-02-2017, 06:10 PM   #5
Not a Number's Avatar
You can find a copy of the user manual for this bellows and slide copier here:
Pentax auto slide bellows A, Pentax Slide copier A instruction manual, user manual
01-02-2017, 06:12 PM   #6
QuoteOriginally posted by baro-nite Quote
Ahhhh. This works better. This was really an experiment, first try, not to impressed with the results. Attached is a slide, which is pretty sharp using a loupe. Looks like this system causes the outside areas to loose focus.
01-02-2017, 06:13 PM   #7
Thanks, I actually found this a little earlier. I appreciate it!
01-02-2017, 06:27 PM   #8
Thanks for the tips. I am going to try a Epson v550 scanner. Looks like it'll make my workflow much easier. Should I even consider finding a home for the Pentax Auto Bellows A with Slide Copier A? Or are these pretty much obsolete?
01-02-2017, 07:13 PM   #9
Not much demand for bellows units now. I've had one for Leicaflex for about 45 years and have used it rarely, and picked up an Auto Bellows A and slide copier a few years ago. It works well with a Sony A7, as the adapter gives enough clearance, and as a FF the magnification is right for copies. Slides in glass mounts (sandwiched in glass) stay much flatter and hold sharpness better into the corners, but re-mounting in glass is a pain. I have gotten fairly decent scans on an Epson v700.
01-02-2017, 07:52 PM   #10
Slide are seldom flat in the slide mount unless you have the glass slide mounts. This would account for why the edges are out of focus. Even when viewing slides in a slide projector you could see some of this. The heat from the projector lamp would often times cause the film chip to flatten out.
01-02-2017, 09:47 PM   #11
QuoteOriginally posted by javapop Quote
Little 6X loupes are not a tool to test for critical focus. For that I use the Autobellows, 40X microscope loupe or my Coolscan. A pro photog had me scan some slides for him and he was disappointed that the results were mostly out of focus so I had to show him it wasn't the scans but the slides themselves.
My 40X microscope. What you can see with this can be captured by the Coolscan.
01-03-2017, 07:07 AM   #12
BigDave's Avatar
Slides in typical paper or plastic mounts do have a cuvature to them.. Mount them in glass mounts, even temporarily, to copy them and you should have good results.
PS- I have the A bellows also and added a short extension tube to the unit and it attaches to the camera fine. If you do not use the extension tube, and want to do a vertical shot by spinning the body on the lens axis, you cannot do this with the DSLRs without the extension tube.
Regards,
01-03-2017, 07:39 AM   #13
WPRESTO's Avatar
Another point about copying slides with a Pentax bellows + slide copier. If you are using an APS-C sensor, it is not possible to copy the entirety of a 35mm slide. I have tried with my K3 and Bellows A using 40mm, 50mm macro, 70mm, 100mm bellows and 50mm APO Componon lenses and no combination will allow copying all of a 35mm slide using the Bellows A and the slide-copy attachment. I have not yet tried with my K1, but its FF sensor should be able to copy all of a 35mm slide using a 50mm macro as the transfer lens, possibly using the 50mm APO Componon, although with the latter some step-up filter rings are needed to connect the slide-copy attachment to the front of the lens (necessary to avoid light-leaks from the side).
01-03-2017, 09:00 AM   #14
gofour3's Avatar
Pentax also made the Slide Holder K, that was an extension tube with a slot for the slide at the end.
PENTAX Slide Holder 1x, K reviews - Pentax Camera Accessory Review Database
Phil.
02-25-2017, 06:26 PM   #15
JimJohnson's Avatar
Location: Summer:Lake Superior - Michigan Winter:Texas Hill Country
Look here: ...and scroll down about 4-5 posts to my post with instructions and photos .... This post was five years ago with my first APS-C camera (Kr). I've migrated a couple times to a K-3 and tweaked the process a bit (you have to also put extension tubes between the K-3 and bellows) and I'm using a better lens. But overall the process is the same.
auto, canon, copier, film, k100d, mount, pentax, pentax auto, photography, slide, slide copier, slides
For Sale - Sold: Pentax Auto Bellows A with Slide Copier A Mbaker Sold Items 10 02-27-2013 09:05 AM
DSLR with Auto Bellows A and Slide Copier grjmn Troubleshooting and Beginner Help 4 02-16-2013 11:19 AM
Bellows and Slide Copier A with EL Nikkor 50mm f/2.8? baj Pentax Camera and Field Accessories 14 08-05-2012 05:47 PM
All times are GMT -7. The time now is 12:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
