Originally posted by stevebrot Are you buying new or used?
The scanner is fixed focus and adjustment is made by adjusting the height of the negative carrier. The stock Epson carrier support three vertical positions and yes, you should use the carrier to take advantage of the better of the two optical systems on the scanner.
You should be able to do much better with either method than your example photos above. How does the negative look in the loupe? Is it acceptably sharp when evaluated directly? Are you sure you are recording the emulsion side?
That particular image was, I believe on the wrong side of negative, I turned it to fit the frame into lamp (flat, cold LED panel ), I did not make a good setup for macro, still exploring the methods.
The other negatives are better, but they are personal to post online. I made mistake practicing on with personal pictures first. Now I will select non-important negatives to practice.
The point is: my properly mounted film in Epson carrier comes out terrible. Period. Blurry compare to those taken with macro (either Tamron, or DA 35mm)
Placed on the glass bed on scanner, they comes noticeably better.
I got that idea: adjust focus by changing the distance between film and scanning bed. I can buy custom frames, yes, but not really excited about wasting about $100 for the pain of manually nailing the focus with adjusting screws. I can get that pain for free making own frames.
I have only 35mm film to scan, not bigger. It seems that 35mm film is the worst with Epson v700 according to reviews online.
I can imporove the set up with macro lens, and buy the light pad. (which is around $100)
I can buy custom rails for V700, which are also around $100.
Or, I can put that $100 toward the scanner without any headache.
So far I'm looking for minimum headache solutions. Preferably around $200, used or new. Seems like to get a good new solution for that price range is not realistic so far.
