Originally posted by MJKoski
NAS is a failure in a way that you cannot keep backup drives in separate locations (in case of thievery or fire etc.). Fire would waste films on the other hand
I have no desire to argue on anything, I put a suggestion forward for the OP to consider an alternative to just buying an external HDD or two.
When you consider the two NAS systems I referenced you need to understand they're not just an expensive external hard drive as they provide options for offsite back up via the internet. You can also separate locally held unitsusing your household network too, though protection from fire/theft still needs to be factored.
Offsite back up can be achieved by utilising your own or their cloud storage solutions, of course the OP has identified shortfalls in cloud storage so with an NAS system you have another alternative. And this is where these systems provide an solution similar to buying an external HDD and sending it to a family member for safe keeping as an offsite back up. However instead of this manual approach you can have another NAS of the same type at the other family members home connected to the internet and you set up the system to enable back up to this second unit.
Yes this is more expensive than just buying a hard drive and storing it with family, and if that's what the OP is happy to do then cool. A good NAS System provides the option for off site back up, in real time without ongoing cloud costs hence I thought the OP might be interested.
Oh, and the failure rate for optical drives like DVD is too high unless you buy archive standard discs and protect them from disc rot. Also, soon SDD will provide a more stable solution than HDD as their capacities rise and the costs come down. SDD have a max number of cycles before failure so again a finite answer to storage but one that has probably the most potential of the current options. The latests NAS units are incorporating SDD options too as well as SD card readers to facilitate fast data transfer.
Tas
