Originally posted by gofour3 OK I'm dying to hear why. Have a roll of the daylight 50 in the fridge and have used that film for a couple years.
Phil.
I bought a roll of 50D from a generally well-regarded online retailer. Didn't use it immediately but kept it in the fridge until use, which was still within the 6 months advised by the company (at least from the date of purchase). Eventually I got round to shoot it and had it developed at a lab I had already used and trusted in the past. When I scanned the negative, though, most of the frames were covered by a sort of cloudy red pattern. At first I thought it was a lab's developement problem, and was about to have it reblixed at a friend's to see if it got any better, but then I decided to run a search online anyway. Turns out what I was seeing was "age fog", as per the company's own findings. I contacted them to be sure and they confirmed it (and sent over a free replacement roll, so kudos to them). They explained that any rolls that were undated were likely old stock (they started dating them when they found out about the issue), so even if I had used it within the six months period from purchase, the film had probably been sitting in the shop for a long while already. They went on to recommend another retailer.
Bottom line, only use CineStill that has an exp. date on it, use it within the given period, and expect anything old or undated to have gone bad.
---------- Post added 02-07-17 at 00:27 ----------
Originally posted by pathdoc It's months, not years; box speed should be fine.
I note two people have advised you to shoot it as if it were ISO 80. Are you sending it out or developing it yourself? If you're sending it out, you could consider asking the advice of the people doing the processing and they might give it a bit of a 'push' for you (whatever small amount it takes to push an ISO 80 film to 100). If you're doing it yourself, that process is under your control.
For those giving the advice, how does this change OP's development time (given that he can't change ISO manually)?
It's more to do with the film itself than and age-related advice. Acros seems to be more of an ISO 80 film than an ISO 100. Then again if you're not processing yourself you'd probably just want to use it as is, there are so many other variables out of your control it's hardly going to make a difference.
Since he can't dial in a different ISO and only has 1-stop exposures available, either forget about that and use box speed, or if you really wanna give it a go, try hacking the DX code on the canister (never done it myself, but a friend of mine did and apparently it worked).
