Hi, Team,
I just started developing my own film produced by my Pentax 67. The times when I've done it right have worked out amazingly. And the times that I've goofed... well, not so amazingly.
I'm wondering if you can help a little bit.
I've developed a total of five rolls of medium format film. The first two were done with supervision from a guy I know who has the whole process figured out. He's got a darkroom we work in. They turned out great, and some of the prints did too. The last three rolls I did on my own. And I definitely goofed up.
I'm using Ultrafine Xtreme 400 120. I have a pretty standard press kit; Kodak D76, Kodak Fixer and Hardender, Photo Flo, and I'm skipping the stop bath. I'm doing this all in a developing canister.
I've been using an app on my smartphone, Film Developer Pro, to help guide development times. But I discovered a few problems with my last three developments when it was too late.
First, I have been developing at about 80 degrees. I didn't know that developing warmer would have a negative impact on the film (larger/uglier grain, I guess?). I just thought you had to adjust the time, which I did. Since its so hot in Missouri, my tap runs at about 82 degrees.
Second issue was that for the last two rolls, I used twice the concentration than what I calculated for. I meant to do a 1:1 developer dilution, but I used full strength instead, because I'm still getting my bearings, and forgot to cut the solution. The last roll, I realized this at about 2 minutes too late for that reaction. At full strength and at 80 degrees my development time should have been 4:30, but I went to 6 minutes before I dumped it and started the wash.
TL;DR: I overdeveloped the hell out of some film which I really hope doesn't ruin it. I also developed way too hot. What do you think the impact will be on the negatives? I haven't made any contact sheets or prints, or even scanned the film yet. I need to go to my friend's lab for all that stuff and he's tied up for a week. I'm dying to know if I killed the negatives (although to the naked eye they look fine).
Last question: Whats the best technique for washing film when the tap is running way hot? Do I just need to refrigerate water for the wash in between developing and fixing?
Thank you for the help!
