Hello guys,
This question will have been asked hundreds of times, but each question has several questions, so please, I ask you to help me with your choice.
I should scan a number (approx. 1000~2000) of slides before they deteriorate further. I have three alternatives,
1) I own a
Minolta Scan Dual scanner (SCSI-2) only for slides and negatives used in very few occasions
2) An
Epson Perfection 1660 Photo (for normal scans + negatives and/or slides) is still boxed.
3) A third solution, I could buy a
Pentax Auto Bellows A +
Pentax Slide Copier A, to use with a DSRL that should keep the automatisms with the DSLR.
Which is in your opinion the most reliable solution qualitatively.
Thank you for your suggestions.
