4 Days Ago   #1
mtux's Avatar
Plustek scanner weird results
My recently bought Plustek Opticfilm 8200i scanner sometimes spit out results like the attached photos.
The last one is the prescan inside SilverFast software. This also happened in VueScan. and also I remember once it happened to the prescan image too!
Has anyone seen such phenomena? Any idea what can be the cause of it? I've got the latest driver from plustek website and installed it but it happened after that too. sometimes a rescan is successful, and sometimes like this case multiple scanning results different cases of this. and restart of the scanner fix the issue!
OpticFilm 8200i  Photo
4 Days Ago   #2
As you have used two different applications and updated driver, it sounds like a potential hardware issue. It seems unlikely that a flaky driver would cause this similarly, two applications faulty install and intermittent to boot does not sound plausible. So sounds like a potential hardware issue
Possible cable fault - do you have a spare cable you can swap?
Make sure both ends cable clean including sockets, run other peripherals of same connections - I assume USB?
Can you try and install to another system?
Have you sent a notice to Plustek describing issue or looked at their forum?
4 Days Ago   #3
twilhelm's Avatar
I had some issues with my Plustek and sent them an email. The next day they called me and walked me through the “fix”. In my case, when the driver updated, it clashed with the old driver. We cleaned both drivers out and did a re-install which repaired the issue. Some of my issues were similar to yours, others included crashing. A restart would temporarily fix the issue.
The surprise was them calling me!
3 Days Ago   #4
mtux's Avatar
I don't have another cable or system to test. :|
But I found that there's two drivers installed together. so I removed both and installed the one I got from their website again. Will contact them if this didn't solve it. Thing is it doesn't happen always, It'll take sometime probably for me to know if it's fine or not.
Thanks
2 Days Ago   #5
driver issue, could also be the USB port you're using. try a port on the back of the machine (if desktop).
2 Days Ago   #6
Otis Memorial Pentaxian
QuoteOriginally posted by mtux Quote
Silverfast and VueScan both use their own drivers, so it is unlikely that is the cause. As noted above, a bad cable or port may be the cause as might an issue with the scanner.
1 Day Ago - 1 Like   #7
I'm not sure the driver remark is accurate for Plustek scanners. I'm pretty sure Vuescan uses Plustek drivers for Plustek scanners, since I recall having to install Plustek drivers to be able to use my 7400 with Vuescan.
1 Day Ago   #8
twilhelm's Avatar
QuoteOriginally posted by brofkand Quote
You are correct. This is why I cannot use my model of Plustek on my Linux machine with Vuescan, the Silverfast drivers donít work with Linux and Iíve not been able to locate a replacement. So I keep one computer dual boot.
My issues were similar to the OPs, and very intermittent, but progressively got worse. While talking with the representative, I learned that you must remove the driver before updating it.
1 Day Ago   #9
I think that Steveís remark about two drivers is actually accurate AFAIK Silverfast will have written their own for a specific scanner and Vuescan will use a different version - the manufacturers. I do not think that Ed Hamrick (Vuescan author) writes drivers himself, so if the manufacturer cannot provide him then the likelihood is the scanner will not get support. Things may have changed at Vuescan HQ though?
Probably a moot point anyway as running concurrent drivers is really asking for trouble and with any luck this was the OP problem
1 Day Ago   #10
mtux's Avatar
I have actually tried installing Vuescan without having the driver installed. and seeing message from Vuescan to go and get the driver from Plustek's website. So I don't think Vuescan has its own driver.
I'm also hoping that, double drivers was the cause.
film, photography, plustek, plustek scanner, results, scanner
Plustek OpticFilm 8200i SE Film Scanner Question Biff Film Processing, Scanning, and Darkroom 3 03-10-2018 02:59 PM
For Sale - Sold: Plustek OpticFilm 8100 Film Scanner pleitzxcan Sold Items 5 06-04-2016 10:00 AM
Plustek Film Scanner Black Friday Deals Adam Pentax Price Watch 9 11-21-2013 10:40 AM
Any Plustek scanner users out there?..... UpNorth Film Processing, Scanning, and Darkroom 3 05-23-2012 01:00 PM
Plustek Opticfilm 7200 - Slide Film Scanner ??? shane Pentax Film SLR Discussion 9 09-19-2007 11:24 PM
All times are GMT -7. The time now is 04:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
