06-20-2019, 02:58 PM   #1
Unicolor Film Drum
Has anyone replaced the bottom gasket on a Unicolor Film Drum with a rubber o-ring?
If so what size? I am thinking
It seems my best way to a lot of color processing.
While on the subject, the instructions for using the drum are included in the Unicolor chemical kits,
but the chemical quantity is not listed. I found the following on the internet:
"If you are processing 35mm use 5oz(150ml) for the first reel and 3oz(90ml) for each reel after that to a max of 6 reels.
For 120 film on the 120/220 reels use 7oz(210ml) for the first reel and 5oz(150ml) for each reel after that to a max of 4 reels
for 220 film use 10oz(300ml) for the first reel of 220 film and 8oz(240ml) for each reel after that to a max of 4 reels.
These volumes are the minimum to cover the film, but you may want to use more depending on the dilution of the developer."
I will test this when I can keep liquid inside the drum
Phil
06-20-2019, 03:36 PM   #2
Otis Memorial Pentaxian
QuoteOriginally posted by PWhite214 Quote
There is the sound advice. The key is to remember that the film will exhaust the developer unless sufficient chemical is provided.
Those drums tended to leak, even when new. Good luck.
06-20-2019, 05:05 PM   #3
I have ordered some 1/2 inch epdm o-ring material. The roll is 5', which will be way more than I need.
I am sure there are a lot of these drums around, so I will let y'all know about success or failure.
Phil
06-20-2019, 09:16 PM   #4
Not a Number's Avatar
I never had problems with this drum leaking. I should have the instructions around somewhere but I'm not going to look for them right now
I haven't used it in a good 14-15 years or so but all the seals were fine back then.
The low capacities are because the drum is meant to be used with constant agitation on a mechanical roller and the chemicals discarded rather than replenished and reused.
drum, film, max, photography, reel, unicolor, unicolor film
Low tech drum film processing stevebrot Film Processing, Scanning, and Darkroom 4 01-23-2018 07:39 PM
Scans of Fuji Neopan 100 Across and Ilford XP2 Super 400 from a drum scanner. Stagnant Film Processing, Scanning, and Darkroom 3 10-16-2017 06:53 AM
Abstract Bang the drum. SpecialK Post Your Photos! 2 04-18-2014 07:21 PM
Unicolor Bold in PP ruggiex Digital Processing, Software, and Printing 14 07-14-2013 06:45 AM
All times are GMT -7. The time now is 05:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
