Originally posted by c57d
Negative Lab Pro has a Cyber Monday coupon for $10 off.
It's ANALOGMONDAY
Has anyone done a pixel shifted digital image and compared it to a scanned image?
If so, which did you like better (and which scanner did you use)?
Chris
I've only compared my Coolscan 4000dpi scans of 35mm film to my K20D (15MP) and to a Nikon D800(36MP).
I started off with a frame of film with sufficient detail to distinguish what the scan can resolve as well as not resolve. For the film I used Kodak Techpan shot at ISO25 and developed in Kodak Technidol. To ensure suffient detail for reference I used an 12233 resolution chart arranged 4 high. I used my Pentax LX+Pentax M 50mm f4 macro under optimum settings - tripod, MLU, sufficient lighting and shutter speed and varied apertures. I then scanned/copied the various frames and this is the "best" from the lot although there were actually a few that were equally as good.
Full res ->
Kodak Techpan scan compare
The full shot is shown in the bottom left.
The 100% crop of the center area of the K20D copy is above it.
The 100% crop of the center area of the Coolscan 4000dpi scan is above that.
The 100% crop of the center area of the D800 copy is top left.
You'll notice the Coolscan resolves a little bit more than the D800 even though there are more pixels from the D800.
For the big 100% crop to the right, I used my K20D+autobellows+Pentax M 50mm f4 macro to magnify the center area about 4.5X. You'll notice the detail that was not resolved by the methods above.
I originally did this to test my lenses - all of which I bought used, and I wasn't sure if they were good performers. I first tested them on my K20D and they seemed fine so I tested them further using Kodak Techpan. After these tests I feel good about these lenses although now I am not sure what limited the resolution of detail captured on the film - was it the film itself or the macro lens?
Reason: Develop using Kodak Technidol
