Originally posted by LenH55 Hello,
I have several thousand b&w negatives to digitalize, I am now partway through. My k5iis is set for monochrome and best quality jpeg. I have PS cs4 for post-processing and all of the pictures do need it if for no other reason than converting to positive.
Here are some of my questions. If I save a picture in jpeg AFTER editing will it be compressed again? If so is there a way around this by saving the image in another file format?
It is important that the file format is compatible with standard, native (ei. windows) photo viewers as the images will be sent to others on thumb drives. Obviously the file sizes should be as small as practicable.
Would copying these images in raw and ultimately, after editing, saving them in jpeg be a better route? Does anyone have a roadmap for that?
Any thoughts that you may have on the above will be greatly appreciated.
Len
Every time you save a jpeg you lose detail. Will you notice ? I very much doubt it. You say you want to send the files as small as possible...that will lose more data than saving a full size jpeg a number of times.
Use jpeg in camera. I suggest not using b+w in camera. Do a few test shots and see if you like the end product.
If it is not giving you the contrast or tonal range you want then try raw, but this will be a much longer process. How are your raw processing skills ?
