Originally posted by Jonathan Mac Tri-X's biggest negative (boom boom) is that it's so curly, and I'm talking about the current stuff. I imagine 35 years ago it might have been even worse.
I flatten all my negatives before use as a matter of course, even ones that are already really flat. One night will not be enough, and neither will one heavy book. If you have space, put the negatives in a book or thick magazine and load some packs of water on top of it. Where I live, bottled water is widely sold in six-packs of 1.5 or 2 litre bottles, which therefore weigh nine and 12 kilos respectively. Use at least two such packs and leave them there for at least a couple of weeks.
Failing that, put them in a thick magazine and put it under your mattress at the point where most of your weight is (though a good mattress will distribute your weight well). If your partner is heavier than you then you could be a bit cheeky and put it under their side of the mattress, just don't come crying to me when they're p*ssed off at you after you told them why you did it.
Actually, flat is flat. Whatever weight is required to flatten them is all that is needed to make them temporarily flat. I say temporarily because if the relative humidity in the surrounding air is too low, the negs will just curl again once the weight is removed.
---------- Post added Apr 14th, 2020 at 08:15 AM ----------
Originally posted by dsmithhfx FWIW, they're in a glassine negative sheet.
That won't make any difference.
