06-03-2020, 11:45 PM   #1
Compensate expired B&W film
Hi,
I do have an unused Agfaphoto APX-100 136 B&W film that is 5.5 years expired by now.
Despite this, i would like to use it (on a Pentax analoge camera i guess) (and develop it myself).
Can i compensate for it's age by modifying exposure setting/developing time, so to get good results nevertheless?
When your answer is 'yes', i would be grateful for suggestions (best from some who had the same issue before).
Thank you,
lowlandspentax
06-04-2020, 01:41 AM   #2
Medium speed B&W films should keep very well, especially if properly stored (not too hot). I would give it just slightly more light, like +1/2EV, than fresh film and develop normally. Stored too long/too hot, B&W film gets 'fogged' over time and higher speed film loses sensitivity. Increasing exposure helps to work around both effects, but may of course make highlights a bit dull.
I recently developed some APX100 which expired in 2003 and was stored at room temperature. Developed normally, there was a slight fogging and in the very bright parts of the negative, the numbering from the backing paper (120 format roll film) is visible.
06-04-2020, 03:39 AM   #3
If you have more than one roll, use the first roll to test for necessary compensation. There are is no rule of thumb for compensation and the amount of surprise can be reduced by testing first.
06-04-2020, 07:33 AM   #4
If you only have one roll, shoot a couple of exposures and cut then develop. I have used a changing bag, but going into the darkroom is much better.
Phil
06-04-2020, 08:07 AM - 1 Like   #5
Develop it normally.
06-04-2020, 09:20 AM   #6
Shoot a gray scale, develop normally, and judge from the negative for development changes needed if any. Old film can pick up some fog but that's unusual for 100 speed so I would guess if it has been stored well, it will work fine.
06-12-2020, 05:42 AM   #7
fs999's Avatar
I used the Rollei equivalent Retro 100 in Caffenol CLCS 70min stand @ 15-20C
06-12-2020, 09:39 AM   #8
ChrisPlatt's Avatar
I too have some of the last Agfa Gevaert 35mm APX100.
Mine has always been stored cool or cold but not frozen.
With normal development the negatives come out fine.
Chris
film, photography
If your expired color film has a color shift, can you compensate with a lens filter? goatsNdonkey General Photography 7 02-07-2017 03:03 PM
How to compensate for ultrawide blown highlights DeadJohn Photographic Technique 7 02-28-2012 08:47 PM
AF280T Flash - Need to compensate for ceiling bounce in TTL? iht Troubleshooting and Beginner Help 6 08-19-2010 06:58 PM
Anyone else do this? ISO 100 and compensate with flash/EV/aperture? ChooseAName Pentax DSLR Discussion 14 07-29-2010 09:59 AM
Distance to compensate for crop factor bodhi08 Photographic Technique 20 03-27-2010 04:07 PM
All times are GMT -7. The time now is 01:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
