Originally posted by yucatanPentax Well, I'm very interested in the easiest and painless way to scan slides and negatives. I don't have a ton. All are at least 40 years old. It doesn't make a lot of sense to invest in expensive equipment. The commercial solutions I tried returned very very poor results. So, they remain unscanned or unduplicated.
Something "easy and painless" would be most interesting!
Hi all,
As I said I was skeptical too, since the tendency is to use either a scanner or a service "let's say I do you a good job...all to prove", what is the cost?
After having almost put aside the idea of digitizing old color or B/W negatives because it's too demanding and expensive, I saw the movie of a friend of mine who proposes this solution.
Needed:
1. Get a cardboard box or other material.
2. It must be tall and wide enough to hold a tablet or a light panel (on Ebay, Amazon), I opted for one of my tablets I installed an app that allows the lighting of the entire screen.
3. A DSLR (I use mainly K3II, but...)
4. A bubble level for the parallelism of the planes.
5. A macro lens (I use the Pentax-F 50mm f/2.8), but everyone uses what he considers appropriate.
6. A wired or infrared remote control for the camera.
7. A tripod where you can position the head at 90° or reverse it (I used this solution).
Execution:
1. Practice two carvings (with a cutter and a ruler) of the format of the negative or slide (a few mm more is better), I practiced 2 one 24x36 mm and a 6x6 cm, it goes without saying that you can create the format that best suits your personal needs.
3. Inside the box insert the tablet, turn it on and start the application when you start the work session.
4. Now mount the camera, check with the spirit level that the SLR display and the box are parallel and level.
5. With the DSLR mounted, perform white balance.
6. Activate live view, choose M mode or if you prefer AV. "make sure to activate Focus Peaking".
7. Focusing must necessarily be manual.
8. At this point the game is done, place the slides or negatives (you can use the appropriate holders), and shoot with the remote control to avoid vibrations.
It seems a tortuous and/or long procedure, but once started the mechanisms will become automatic and everything will be very simple.
N.B. The saving is considerable and the results following step by step, are like other expensive solutions, after all the digital camera is also for this.
P.S. For those who have many negatives (mostly color) I recommend the software to be combined with Lightroom, NEGATIVE-LAB, because as someone suggested in other discussions, reversing in PS or other software is not the same thing, although there are excellent tutorials on the web.
For fast viewing of Raw/Dng negatives, I recommend the excellent ''FastRawViewer'' viewer that allows a real view of the Raw in real time.
I enclose two snapshots on the fly of my mobile workstation. If I've forgotten I flew over some topic is for distraction, in case let me know if you like this simple and inexpensive solution,
and independent from the operating system.
Ciao Mario
