10-02-2020, 03:20 PM   #1
Cleaning ball bearings in Paterson reels
Hi All,
I have recently been having some issues with residue on the ball bearings of my plastic Paterson reels. I am not sure which chemical is getting stuck on there but it means that there is some tension and gunk when I load a new roll onto the reel (120). It leaves some markings on the film once it has been developed.
I tried soaking them in hot water and detergent and then scrubbing with a toothbrush but it didn't really work.
Does anyone have any solutions for something that may get it off and clean again?
Thanks.
10-02-2020, 03:35 PM   #2
Otis Memorial Pentaxian
Have you been processing cine film (remjet intact)? You might try ammonia.
10-02-2020, 03:39 PM   #3
I used Ronsonol lighter fluid to clean aperture blades and shutters. That may work.
10-02-2020, 03:42 PM   #4
Not a Number's Avatar
Suggestion I've seen are to soak in dilute vinegar or ammonia then scrub.
Other suggestions are to remove the ball bearing and not bother with it at all.
10-02-2020, 05:27 PM   #5
pres589's Avatar
How well does the film "ratchet" and keep advancing with the ball bearing removed? I have AP reels which are a copy of the Paterson's and would assume the ball bearing is worth saving.
I do the *worst thing imaginable* to clean my reels, so really, don't do what I do; rinse the reels well after use, put them in a delicates bag, and toss them in with my laundry one at a time. Works great and so far so good. I've only done this a half dozen times so far but I think it will continue until something goes wrong and I'll complain about it here on the forum.
10-02-2020, 08:41 PM   #6
Just slide the film in without the balls. That's how my Unicolor reels work. If it binds just twist the reels a bit. Loads even faster in my experience.
10-04-2020, 03:38 PM   #7
Russell W. Barnes's Avatar
I rub my Paterson ball bearings with a soft pencil before use and ensure they're free to rattle in the slots. Seems to work! After use I wash tank and reels and jugs etc... in warm soapy water, rinse thoroughly and leave the reels split in two to dry naturally on the window sill after I've tapped them on a towel to get the bulk of the water off.
10-07-2020, 02:14 PM   #8
ChrisPlatt's Avatar
I always thought the discoloration was rust...
Chris
10-08-2020, 10:08 AM   #9
Wheatfield's Avatar
QuoteOriginally posted by davewell83 Quote
Hi All,
Thanks.
Dishwasher (not dishwashing) detergent seems to remove just about everything.
ball, ball bearings, bearings, bearings in paterson, film, paterson, photography, reels
People Woodland Park (West Paterson) - Parade gilberteid Post Your Photos! 0 04-23-2020 05:31 PM
B&W Paterson Tank What am I doing wrong? montman Film Processing, Scanning, and Darkroom 17 01-25-2013 11:00 PM
Vivitar Kiron/Kino lenses and their ball bearings vonBaloney Pentax SLR Lens Discussion 4 12-18-2012 09:37 PM
Loosing my Bearings telfish Pentax SLR Lens Discussion 16 09-30-2009 03:40 PM
All times are GMT -7. The time now is 03:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
