Originally posted by DWS1 Don't know the solution, but I've noticed the same effects.
Interesting. Good to know I'm not the only one. Thanks.
---------- Post added 06-24-21 at 10:49 AM ----------
Originally posted by LesDMess Curious, when you shot the first one "Grainy noise in the sun", did you meter for her face? If so, did you compensate for the very high backlighting by overexposing by at least 1 stop but better with 2 or even more?
Do you have access to another scanner? This would just eliminate your scanner from being the issue or not. The reason I ask is I am guessing your scanner is trying to "auto level" what I think are very dark frames depending on how you metered in my question above . . .
That's a good point. I also thought my scanner might be using some kind of auto level. I'll try different scanners.
I metered for her face. I didn't know overexposing it 1 or 2 stops was a thing even though something in the back of my mind told me I should try it! This, I believe, is my first time trying grossly overexposed backlight so I wasn't too experimental.
Thank you!
---------- Post added 06-24-21 at 10:50 AM ----------
Originally posted by Aaron28 dust on scanner bed? generally when i get a magenta bar through the frame it is from dust......maybe the diagonal lines could be from the same......have not experienced that.....have the epson v600
Interesting. The scanner bed seems clean.
Thank you!
---------- Post added 06-24-21 at 11:05 AM ----------
Originally posted by steephill You also have vertical lines on the first scan which means that your scanner needs cleaned, particularly the calibration strip. The diagonal lines look like a scanner artifact but the grain is simply the result of pushing the performance envelope a little too far. More information would be needed to help diagnose the problem - e.g. what scanning resolution are you using? How much gain are you using? I notice in scan 2 that you are scanning right up to the edge of the film, try cropping in a little to avoid Vuescan using the dark edge to set the scan exposure.
I also thought the performance envelope was being pushed too far. I believe I used 600DPI for jpeg. I have no idea how much gain I'm using. How do it check that? I think I tried cropping a bit more but I'll try even more to see if that makes a difference.
The vertical lines are actually from squeegeeing it too hard. It's the damage I created on the neg myself. But, that makes me curious. Does the scan 3 w/o noise look like it needs cleaning? I've never cleaned it since I bought it so I'd love good cleaning done.
Thank you!
---------- Post added 06-24-21 at 11:07 AM ----------
Originally posted by tuco How much over exposed? When you see "grain" like that in the highlights, you are adjusting the contrast curve it too much in a direction the film doesn't want to go for that exposure/development. You see it a lot in small format images.
There are two basic approaches to scanning. One, you adjust the contrast curve in the scanning software to taste and final image. And the other you scan to grab as much density off the negative as the scanner will do and adjust the contrast cure in an image editor. You will most likely have a flat, dull image with that method initially but the more advanced contrast curve control in an image editor will give your most latitude.
This is really good to know. Thank you!
