08-25-2021, 12:27 AM - 1 Like   #16
fs999's Avatar
There is also an experimental module for Darktable.
Silkypix has a tool.
FilmLab do that too.
There is also a plugin for photoshop NegMaster.
08-25-2021, 09:41 AM   #17
Excellent food for thought. I was actually thinking of posting a similar question so to keep from adding a redundant thread and to promote further discussion I’ll jump on here if that’s ok.
I’ve been scanning with Epson V500 and have largely been pleased with my results at least for 35mm (not real pleased with 16 mm however).
I’ve got a LUMIX GH3 (mft of course) that I think should be good enough (16 mp I think). Was thinking of using my M50mm/f4 lens +\- extension tubes as needed vs Tamron adaptall 60-300 lens which does mighty fine “macro.”
I like the idea of a copy stand but wanted to do this on the cheap and not have some bulky apparatus to store. I was thinking of creating a stand which would hold the negative holder upright and just move the camera on the table or put books under it to get the height right. I was going to use an old manual flash with adjustable output for the light source (but would not be against using an iPad or buying a dedicated light source if it worked out well).
I had not put much thought into how I would process the images. Since it seems like a lot of people are doing this I had just assumed there was a free app that converted the negative images and I’d use my old copy of LR5 to process the images. But perhaps it’s not quite that easy.
I wanted to do this as a sort of experiment to see if it was better (faster, better quality) than the v500.
Any insights on the above are welcome. Thanks .
09-25-2021, 10:05 AM   #18
QuoteOriginally posted by PenPusher Quote
My Epson 3170 from way back is on its last legs.
It seems to me that there are now 2 ways to scan, I suppose really digitise, both negatives (mostly discovered 6 x 9cm from long ago) and prints:
A - Buy a new scanner of which the best specified and affordable I can find is the Epson V600 @ around €330, the v850 is obviously better but at least 3 times the price.
B - Use my Pentax (K-70) with a macro lens mounted on my old enlarger column and a light table for negatives and a bit of studio lighting for prints. I have a light table and some studio lighting. I have an 50mm M F4.0 lens.
The question I have is does one have a particular technical advantage over another, ignore the cash saving of the Pentax system.
Kind regards
CD
If you use true b&w then DSLR scanning is a probably a better choice as scans can be very fast with the right setup, ICE (dust and scratch removal) doesn't work with b&w and post work is very simple.
If you use slides then post work is just as simple as b&w, scans are faster but now the lack of ICE can add time in post work.
But since you say you are going to use it for color negatives then be prepared to add considerable time in post work and even more if you need ICE. There are many vids on youtube about this as well as some here who have gotten really good results.
epson, film, lens, light, negatives, pentax, photography, prints, studio, table
Alternative methods to de-yellow your lenses without the discontinued JANSJÖ Lamp tsoybeans Pentax Lens Articles 10 07-02-2021 08:07 AM
Methods for leatherette removal and preservation? Aaron28 Film SLRs and Compact Film Cameras 7 05-09-2021 04:36 PM
Overview of digital camera colour detection methods dosdan Photographic Technique 3 10-09-2011 01:14 PM
Cleaning lens - your methods CRMassart Pentax SLR Lens Discussion 27 04-08-2010 04:36 PM
Need help with lens testing methods JohnBee Pentax SLR Lens Discussion 4 12-24-2009 09:29 AM
All times are GMT -7. The time now is 09:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
