Originally posted by tuco I did a quick search but couldn't find Adox's wash time recommendation after using their fixer with film. But Kodak recommends washing 30 minutes after using their rapid fixer. That can be reduced to just 5 minutes of wash time if you use Kodak's Hypo Clearing Agent according to their instructions. That can be convenient.
Originally posted by Viking42 On the subject of fixer and wash times, you really don't need a hardening fixer for films. As tuco mentioned, that would require an extra processing step with hypo clearing agent. I would recommend using Ilford RAPID FIXER, which is a non-hardening fixer (no hypo clearing agent required). You can then use their their quick wash method. I've been using this fixer and wash method for years, and it really works well. Films look the same many years after processing....no visible degradation at all.
I'm not sure whether Adofix Plus is hardening or non-hardening... I can't find any definitive info confirm one way or the other (though I
do know it's a "rapid" fixer). However, Adox has a
film processing tips page on its website, which gives the following advice for washing:
Quote: WASHING
• You can wash films with running water or with the fill/dump technique
• Special force film washers that get attached to the faucet are very good to ensure proper movement of the water inside the tank. The wash time should be no less than 8 minutes.
• Alternatively, you can fill the tank with water, agitate for two minutes, empty the tank. Repeat at least 5 times with fresh water.
• Using Thio-Clear significantly reduces wash times, as it helps to eliminate residue fixer from the emulsion.
• After the film has been washed, one minute in Adoflo wetting agent is necessary to remove water stains – you don’t want to skip this step!
• If your film base is still pink or blue, this is a residual anti-halation dye. It´s a myth that you have to fix the film until this dye disappears. It quickly fades away under sunlight. The AH dye in the developer and fixer also clear in a few days.
• Some films curl when drying. Placing a clip on the bottom as a weight makes them dry quite flat. The drying environment should be not dusty, as all dust will attach to the wet emulsion.
It's all generic advice based on using the range of Adox film-processing products, and doesn't mention Adofix Plus specifically - but I'm assuming it includes that product. The highlighted steps above suggest five washes of two minutes each with agitation, followed by a one minute final wash with wetting agent, with a recommended use of Adox "Thio-Clear" (which "
accelerates and ensures proper elimination of sodium/ammonium thiosulfate (fixer) from the gelatine layer of your films and prints") to reduce wash times. Does this recommendation suggest Adofix Plus is a hardening fixer?
Frankly, the only reason I chose Adofix Plus is that it was the best value rapid fixer for the quantity I wanted, from a company I was already going to be placing an order with (and, hence, included in the shipping price for the rest of the order). They don't stock Ilford Rapid Fixer in smaller than 1 litre quantities. In retrospect, though, there's absolutely no reason I can't buy it somewhere else instead, and based on your advice it seems like this is my best course of action.
What all of this makes me realise is that I need to read up on the chemistry of film processing so I understand it to some extent, rather than blindly picking out products
Thank you both!
