As I understand it, fixer can be re-used, but eventually the silver concentration reaches a point where the fixer solution requires more time to fix and eventually will not fix adequately, leading to problems with the developed film over time.
I have read of folks testing fixer with a piece of discarded film and replacing when it doesn't clear. I've heard of them using a "two bath fix", where two baths are used for half the time each, the first bath discarded when it reaches capacity and replaced with the second, and the second replaced with a new solution. I've heard of others replenishing fixer by discarding a small amount of the working solution and replacing with the same amount of new solution.
I'd be extremely grateful if any of you who routinely use Ilford Rapid Fixer could advise on your preferred approach for use, re-use / maintenance / discarding, increase of fixing times, dilution etc. and perhaps share your specific steps - as if instructing an idiot, which, in the matter of film processing, currently applies to me!
Many thanks in advance
