After receiving advice on developing B&W film at home (for which I'm eternally grateful to all who provided input), I recently developed my first roll of 120. Somewhat surprisingly, it was quite successful... but I made some mistakes and learned some lessons in the process.
I used a Paterson changing bag while preparing and loading my film. The first "issue" I ran into is that the bag feels much smaller than it looks when you're working inside it, especially with the AP universal tank in it, and the top has a habit of sagging and getting in the way of things. After unrolling the film from the backing and separating the two, I needed to cut off the adhesive strip left on the film, and found it tricky to keep the bag out of the way of the scissor blades. I worried that I might cut through the bag and expose the film, ruining both. I decided that the kitchen scissors I used are too big, and I need to pick up an inexpensive smaller pair (possibly with rounded ends?).
Loading the 120 film onto a reel was a little challenging, despite several practice runs in advance (with different film stock - relevant, perhaps?). After a number of unsuccessful attempts, I placed the unmounted film in the tank without the reel and secured the top, took my arms out of the bag, and made myself a restorative cup of tea! While drinking that, I looked on YouTube for some tips, and found that straightening the curl in the end of the film roll (by gently bending it back on itself) can help. On my next attempt, this is what I did, and it worked perfectly - I was able to load the film without any problems whatsoever.
At the developing stage, I had jugs containing 590ml of developer solution, the same quantity of water (instead of acid stop) and fixer solution, plus an empty jug for measuring water washes and several plastic bottles full of room temperature tap water - but I didn't label the jugs them. The developer was obvious, but When it came to the "stop", I couldn't remember which jug had water and which had fixer solution - and because Ilford Rapid Fixer is low odour, simply sniffing the contents of the jugs didn't help. Eventually, by looking at the liquid at an angle, I could see that the fixer solution was a bit thicker and the mix was swirling in the reflected light (I don't know if that makes sense?). Even so, I wasn't entirely certain I got those jugs the right way round until after the process was completed. Also, in my haste, I discarded the fixer solution rather than pouring it into an awaiting storage bottle (to my horror, as I'm an evironmentally-aware chap). Wasted fixer, and a bit of silver in the drainage system - oops
After the final washing and wetting, it was time to hang the film to dry - and at this point I noticed that when cutting the adhesive strip from the end whilst in the changing bag, I'd cut too much off. I hadn't cut into the final photo, but I didn't leave enough spare for the hanging clip. As a result, I had to clip over the edge of that last photo (though I was still able to save it by cropping after scanning). Also, the film looked really wet (looking back, I guess it would
), so I decided to use my fingers as a squeegee - but I was wearing a woolly sweater, and hadn't realised that some of the strands from that sweater were on my wet fingers. When I squeegeed the film, I transferred the strands onto the film
I managed to remove most of them, and thankfully none of them contaminated the photos - but I was annoyed at myself for that one!
To those of you seasoned in film development, I'm sure the above doesn't sound too bad, but I found it all a bit stressful on this first occasion. For my next roll, I've learned some lessons to make life easier:
1. Don't wear clothes that shed fibres
2. Use smaller scissors in the changing bag
3. Leave the 120 film attached to the backing paper at the adhesive strip, and push the scissors up against that while cutting to avoid removing too much of the film, and to keep the cut straight
4. Bend back the ends of the film before trying to load onto the reel
5. Label all jugs of solution
6. Have a reminder list of steps at hand, so I don't forget to save the fixer
Despite my mistakes, I got a pretty decent-looking set of negatives and - considering they were only test shots - I got some keepers that I'm quite pleased with, if only for the fact that they're my first home-developed shots
Cross-posted from the "Post your B&W photos" thread, here are four of my favourites:
