Originally posted by BigMackCam I've read quite a lot about many films having a box speed that's arguably higher than the "real" speed... for instance, ISO 400 films that are allegedly closer to 320, 250 or even 200 in reality. In several articles and posts I've read, the suggestion is to shoot at "real" speed rather than the box speed... but no-one ever mentions if the development times change. I assume they don't. So, if I shoot Fomapan 400 at, say, ISO 250 - 320 (as many would suggest) and therefore technically over-exposing it with reference to box speed, do I keep the development as per the Massive Dev Chart timings for ISO 400?
To the original post I'd like to clarify some aspects:
While the general recommendation "to expose for shadows" or to somewhat overexpose film (on principle) is valid for both negative BW films and for negative color films, that is a more of a hint than a rule and it relates to the broad
exposure latitude of negative film. Positive film (slide film) doesn't have that much wiggle room. But because Mike mentioned Fomapan 400, let's assume negative black and white film for subsequent considerations.
Most people used to send their film to a specialized lab for development. Nowadays, and more specifically when using negative black and white films, I reckon that most people enjoy to develop that kind of film at home and thus begin to experiment and more precisely steer towards a desired result, through control of development parameters, as compared to a more uniform or "standardized way" pursued by labs, which doesn't fit everyone's preference all the time. Whereas color film is processed with
C41 process /chemicals, the same way all over the world, negative BW film allows for a wide range of different chemicals and processes. There is no standard.
The analog process has two parts: exposure and development. Let's ignore part 3, darkroom printing. Assuming that the exposure was "done the right way" for a given "film speed" - may that be the "box speed" or your own rating for film speed (aka the exposure index) and
not aiming for push- or pull- processing, let's see what you can do at home to
properly develop the film. Proper means: according to a personal preference for
density, contrast or
acutance, based on tales that you read or you were told, as a starting point.
It has nothing to do with standards, definitions, "real speed" or the absolute truth .
Variation of development time ( +/- deviation from an established recipe - such as the one that you get from
Massive Dev Chart) leads to modified contrast levels, if other parameters are kept as in the recipe.
Let's consider an example from the
Ilford HP5+ datasheet:
Quote: Note. Development times may need adjusting to suit individual processing systems and working practices. If an established system is producing good results, adjust the recommended development times until the desired contrast level is obtained.
Development times in other manufacturers’ developers are included for your convenience and are only a general guide.
On
page 5 of that Ilford HP5+ datasheet is a graph, the
characteristic curve - plotting the density versus the relative log exposure. Here is the
characteristic curve of Fomapan 400 too. That is a hint of what to expect, if you do it right. Notice the 3 curves for 7min, 9min, 11min! Those are three curves, not just one! Guess what happens when you push or pull? You change development time. Just as if you would play with "film speed" at exposure, within certain limits.
Now to the exposure part. All of the above is assuming that you have set
ISO/ASA 400 at your analog camera and this setting, along with the available light & scene, made your camera metering system to recommended a certain exposure, that is defined through a
shutter speed and
aperture.
But the exposure triangle has three parameters. You can change any of them in order to "overexpose" or "underexpose". The ASA 400 setting is not cast in stone! Before the actual exposure you can change the
film speed rating for just that frame, to get "overexposure" or "underexposure", just as you would get on digital in
TAv mode when turning the
exposure compensation + or -, which affects the ISO setting, up or down.
You can expose the entire film at ASA 400 or you can get creative and expose particular frames at a "film speed rating" of your choice. Later, you develop the whole film as for ISO 400, to get desired density / contrast levels. Hence, my answer to the original question, on whether to adjust development times, based on a supposed "real speed" or not, is: definitely NOT,
don't adjust development time for that reason.
