Originally posted by ProfessorBuzz LED light sources, even if diffused, still have hot-spots. Electroluminscent panels behave better in this regard, but don't put out much light. Your enlarger was designed as a system, and so bulbs, lenses, and everything else really go well together.
They also don't have the same spectral coverage - paper is blue-sensitive, and LED colour spectrum isn't really strong in the blue for most "white" LEDs - usually there is a phosphor to help widen the output spectrum. You would want to check the datasheet of the LED sources you are using. Also, some LEDs have really strong UV output and a phosphor to downshift the output into the red. This can really throw you off, since it's not readily visible by the human eye.
I believe in LED panels designed for enlargers, red, green, and blue (tricolor) LEDs are used, so they work with photomaterials pretty well and somewhat match their spectral sensitivities. This also allows dialing in of color correction when used for color, and selection of varying "white" output when working with variable contrast materials. You're right that these can produce hot spots but with suitable diffusion layers between the LEDs and the working side of the LED panel, sufficiently even lighting can be obtained. Furthermore, the surface of the LED panel is not at the focus of the negative plane so that provides further "smoothing" of the light output. Tri-color LEDs can also be employed in the conventional "mixing chamber" type of enlarger head for even better uniformity of light output.
---------- Post added 01-07-2022 at 12:16 PM ----------
Originally posted by filmmaster the flashlights i was looking at, they all have this little issue of very narrow beams via the built in condensor lens. even patents mention them as condensing lenses......................
LED flashlight do use a positive lens which could be classified as a "condensing" lens but its placement relative to the LED causes the exiting beam to diverge. If the LED is placed at the focal point of the lens, the exiting beam will be almost parallel with little divergence ("spot beam"). If the lens then moves
away from the LED, the beam will converge as the light does in an enlarger before it reaches the negative and enlarger lens beyond.
However, in an LED flashlight (with zoom functions), the lens can only move closer to the LED which causes the light beam to expand and diverge - not what you want for an enlarger light source. You can overcome this by putting another positive lens in front of the flashlight and positioning it so the beam is collected and sent on in a convergent beam, so in practice, a flashlight could be used for an enlarger light source but there are many better choices.
