Originally posted by biz-engineer For 1:1 crop of ISO400 film looks pretty good if you'd compare it to something like digital CCD from ~2008 at ISO800.
The random layout and size of the grain on this film are quite different to digital luminance noise, though... Here it appears - to my eye, at least - that it "disrupts" fine detail. It's as if the grain is larger than some of the fine detail the film is clearly capable of resolving (I'm looking at the distant trees in the sheep shot as an example). By comparison, digital luminance noise is laid out in a uniform grid at pixel level, which doesn't seem to cause the same disruption to fine detail...
Originally posted by biz-engineer Would that grain still be distracting when printed 300 ppi?
I imagine it would be
less distracting. At some point in the future, once I've got through a variety of films and developers, I'll have to curate a small selection of my favourite shots and have them printed at a few different sizes to see how they look when compared to on-screen viewing. Regardless of grain, they'll already look better, IMHO... printed photos just look a whole lot nicer to me (a shame, then, that I don't print more
Originally posted by biz-engineer That film grain is distracting in the sky, could it be related to exposure for that particular film, too much or too little?
It
could... though I tend to think not. I examined the negatives closely after developing, and - based on the evaluation guidance I'm referring too, and my admittedly-novice eye - they look well-balanced, having a good range of highlights, mid-tones and shadows, with detail noted both in highlights and all but the darker shadows. They don't show any obvious signs of under- or over-exposure, nor of under- / over-development. The Trip 35's selenium-cell metering is a simple reflected-light measuring device, of course, so it will routinely under- or over-expose depending on the balance of elements in a scene. At best, it's only ever going to be approximate - but it seems to have done a decent job here, and I'm seeing broadly the same grain in all of the shots, so it doesn't seem to be significantly influenced by the camera's deviations from perfect exposure.
I think I'll try HC-110 (or Ilfotec HC) next, instead of Rodinal... and, once I've used up my rolls of Fomapan 400, I might try some 35mm Fomapan 200. It'd be interesting to see how it compares to the 120 roll I previously shot. The grain will look bigger, but I suspect it will be much less prominent than with the 400...
