01-10-2022, 11:50 PM   #1
Banned
well, steel or plastic
for tanks adn reels. is steel worth the huge start up cost?
01-11-2022, 12:28 AM   #2
Plastic tanks fine.
Invest in a reel with big take-up guides for easy threading.
https://www.bhphotovideo.com/c/product/122989-REG/Samigon_ESA325_Multi_Forma...981&
01-11-2022, 09:27 AM   #3
cpk
cpk's Avatar
I am still using my Nikor stainless steel tanks and reels from 65 years ago.
01-11-2022, 10:03 AM - 1 Like   #4
Use what you have otherwise I would start with a Paterson tank and reel. Quite low cost, hight quality and easy to load the reel is.
01-11-2022, 10:22 AM   #5
Alex645's Avatar
Plastic is much easier and less expensive and if you need the flexibility of developing 35mm, 126, and/or 120/220, plastic is adjustable for three formats. Stainless steel theoretically leaches less chems, but I have yet to see evidence of this affecting film.
01-11-2022, 10:32 AM   #6
Otis Memorial Pentaxian
I generally recommend stainless steel tanks unless there is a specific reason to use plastic (I own both). Advantages include durability and ease of cleaning/drying the film reels (persistent problem with the ratchet reels used with plastic tank systems).
01-11-2022, 11:33 AM - 1 Like   #7
I think that every person new to developing their own film has the same question, as did I.
I first used Paterson tanks and reels in a community college B&W class I took, and then used them in my own darkroom for several years and never had any problems with them. Based on my experience, I always recommended Paterson reels and tanks to others. BTW, I developed some 35mm and a lot of 120 as well as 4x5 sheet film in my darkroom.
Beyond what others have said, my experience is that plastic reels are easier for novices to load and so are probably more beginner friendly, but on the other hand it's reputedly very difficult to load film into wet Paterson reels. Metal reels are reportedly easier to load when wet, and also dry quicker than plastic reels, making them a better choice if you're likely to need to develop more than a couple of rolls of film in a day.
I had a 2-reel tank and two reels, and that was a good fit for how I shot.
In any case, I would strongly recommend you practice loading a reel with an unexposed roll of film a few times before trying it in the dark with a roll of exposed film.
01-11-2022, 05:41 PM   #8
murrelet's Avatar
I prefer stainless steel for a lot of the reasons above. That said, SS is a pain in the ass when I get it wrong, which is often. I've mangled a few rolls. Had to start over many times. Given up in frustration and swapped in a Paterson reel and tank in the changing bag. 120 film is easier than 35mm with SS reels.
01-11-2022, 05:57 PM   #9
Eric Auer's Avatar
My most used tank is a Jobo 1520.
High quality, expandable, easy to clean and a great simple twist type reel system with no ball bearings etc.
Lots of accessories and can be used with their motorized lifts as well.
Just a great system of high quality, made in Germany.
Oh yeah, Plastic all the way.
https://www.jobo.com/?ecms_lang=EN
01-11-2022, 11:03 PM   #10
If you process a lot of rolls at a sitting it is easier to wash and dry stainless steel reels quickly.
01-11-2022, 11:12 PM   #11
Banned
originally i had thought about jobo and their line of discontinued paper print drums, but as i am restarting my developing tools I have no issue about patterson or jobo,, All my concerns are the following.
Leakage, is a bad bad thing for me. The AP compact two 35mm/1 120 roll tank leaked badly. At first very little, and then only after the developer was dumped out.. Over time, perhaps 30 rolls of film it went from a few drops , to a steady stream at the end. To the point that i had to keep it inside a plastic bag for containment.
Also, the "best" prints i made were inside that AP compact tank. 5x7. barely fit inside ill admit but it wasnt a long term solution as i never came up with a good way to prevent waterlines on the printing paper.
SO the jobo system is nice, as it would help me get my print drum interest taken care of. And if the jobo claim of making a single tube that can hold 10 spools of 120 format,,,, i could at least do something useful.
But patterson and jobo have never been polite to give me dimensions of their drums.
01-12-2022, 10:30 AM   #12
Alex645's Avatar
QuoteOriginally posted by filmmaster Quote
Patterson and jobo have never been polite to give me dimensions of their drums.
For film or paper? I didn't realize you were asking about paper drums as I have never seen or heard of metal drums being used for paper processing. Here's a link to the BH website where it clarifies how many roll capacity in a certain format each Paterson, Jobo, Kalt, or Samigon tank.
I've never had a leak issue for film except when a student abused the plastic Paterson with a hairline crack.
https://www.bhphotovideo.com/c/buy/Stainless-Steel-Manual-Tanks/ci/760/N/407...981&
01-12-2022, 11:29 PM   #13
Banned
To clarify, NO one, not manufacturer, nor retailer of Jobo or Paterson developing tanks will give me a measurement of physical sizes of the tanks.
if im lucky they will say "2 rolls of film can be developed at the same time"
01-13-2022, 12:24 AM   #14
Alex645's Avatar
Are you wanting the physical dimensions so that you can use a film developing tank for processing paper? Or so that you can 3D print your own drums? You can still find Jobo and Unicolor drums on eBay.
01-13-2022, 02:04 AM   #15
StiffLegged's Avatar
Don’t know about Paterson but JOBO have a downloadable catalogue on their website www.jobo.com
edit: and retailers like B&H give the package size of the box (or on Amazon you might find actual overall sizes of the tanks). That’ll give you an idea of sizes at least.
film, photography, steel
Nature Well well well, look who's up and about! bertwert Post Your Photos! 14 04-29-2021 12:46 PM
Nature Well, well... look who's back! gjtoth Post Your Photos! 10 05-01-2017 06:02 AM
Well ... well ... well ... it looks as if the K-1 price war has begun ... Newfie Pentax K-1 & K-1 II 43 06-15-2016 04:09 PM
Pentax Da35mm 2.4 plastic lens vs Da 50mm 1.8 plastic lens fevbusch Pentax SLR Lens Discussion 24 01-26-2014 06:49 PM
Well, Well, Well.... Caboverde1 Welcomes and Introductions 3 11-22-2009 08:21 AM
All times are GMT -7. The time now is 05:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
