Originally posted by Lhorn Thanks. That makes sense. The film is Astia and Portra.
I’ll probably shoot a roll of each at box speed and bracket by shooting 1 frame regular, 1 stop over and 2 stops over.
At worst I can try to process as c41 and see what wild colors I get.
Well, with Portra you likely won't notice a 2 stop overexposure. In fact, you can overexpose it by 10 stops and still get usable results with the most minor of post work like levels and white balance . . .
At the same time I only tested Kodak Ektar to +5 thinking that would be good given it's a contrasty film compared to Portra but that is clearly not it's limit. I have since made good use of it well above. This applies to all the other color negatives and most all b&w films I have used.
I didn't test Astia 100 in this way but I believe it has at least a 2 stop overexposure range given the results I have gotten from it.
If these were kept refrigerated I doubt if any of it will require any exposure or development compensation. I too was given some rolls of Kodak Royal Gold 25 that was almost 20 years expired and was refrigerated and got these results. Shot and developed at box speed.
