Originally posted by fs999
I heard that some people have put the film directly on the glass with EpsonScan software. Never tried it.
I put the negs directly on the glass (emulsion side down) with my cheapo Epson V370 and the EpsonScan software, with the plastic holder just laid on top to keep them flat. The results are much sharper than using the frame as designed and Newton rings haven't been a problem. But you need to be careful not to slide the film around on the glass or you can get scratches.
I doubt it would make any difference on a scanner with adjustable focus though.
The OP could try putting the 6x7 negatives directly on the glass and holding them flat with a piece of anti-Newton glass. I tried that approach with a piece of ordinary picture frame glass, with lines marked on the glass as a guide to positoning the film, and it worked well apart from the inevitable Newton rings.
