Originally posted by cdw2000 Thanks for that link. I do recall having read that at some point. I do have a decent tripod with a reversible center column. The trick is making the light source/slide holder fixed in place relative to the camera/tripod so I don't have to realign it every time I change slides.
That's the benefit of using a copy stand and a film carrier such as the Essential Film Holder (there are some others). With rubber feet on the light panel, that stays put on the copy stand platform. With a rubber mask on the light panel, or rubber feet on the film holder, that stays put too. Inserting the film and advancing it to each frame doesn't move the setup relative to the camera, which is held firmly in place on the column such that distance and alignment rarely need tweaking.
A decent copy stand and film holder (and light panel or larger video light, depending on what you currently use) aren't cheap, but they're well worth it in terms convenience and consistency. There are all sorts of alternative and/or DIY options, but I've yet to see any that offer the same ease of workflow...
