Originally posted by Alex645 What shot number is in the frame counter on the camera? If it's low, then you might as well shoot the rest of the roll yourself as a test. If it's a high number (20+):
Do you know how to rewind the film?
After rewinding the film and removing it, is it color print film, color slide film, or black & white film?
Color print film will say "Process C-41" on it, and yes you could take it to Walmart, but Walmart does not return the negatives. Seeing your negs will tell you a lot about the condition of the camera. I'd recommend sending it to Dwayne's Photo Lab:
https://www.dwaynesphoto.com/
Color slide film will say "Process E-6" on it and Walmart doesn't process slides. I'd recommend get a prepaid slide processing mailer:
https://www.bhphotovideo.com/c/product/18646-REG/Fujifilm_Slide_Processing_M...981&
Black and white film (unless it's Ilford XP2) won't be processed by Walmart. If you don't know anyone with a darkroom, you can get a prepaid B&W film processing mailer:
https://www.bhphotovideo.com/c/product/1015183-REG/ilford_101513_prepaid_fil...981& I owned a Pentax ME Super starting in 1983, so yes I also know how to rewind film. I opened the camera and there is undeveloped film inside the camera itself, not fully shot. I think it is the beginning of the roll because there is a dot in the counter. I could shoot the remainder of the film in the camera. It says Kodak Gold 200.
There is a completely wound Kodak Ektachrome-X film in an aluminum canister in the camera bag. As I view the film canister more carefully, I see this is slide film. I do not have a slide projector. My folks do but they are 1,500 miles away. Can slide film be developed on gloss paper, as well?
I had the impression from the way this was advertised that the eBay seller was not the original owner of the camera.
Any other advice, especially on developing slide film, and in view of the fact I have no slide projector, would be appreciated.
