Fast digitizing slides with the Filmolino Slidescan
I use DSLRs from Pentax to 'scan' negatives and slides, because the enhanced resolution of pixel shift comes without increasing the number of pixels.
For scanning mounted slides in magazines I use a modified slide projector and mostly the Pentax K-70 with a Tamron 90mm macro. In principle, the light source of the slide projector is replaced by an inexpensive LED Lamp with diffuse light and a mirror placed at an angel of 45° in the light shaft to reflect light falling from above towards the front of the slide. In addition, the lens of the slide projector is removed in order to capture the slides through the opening with a macro lens on a camera.
This year (2022) a company in Swizerland developed a small controller, which automates that process. It's called Filmolino Slidescan and is a little smaller than a regular alarm clock. The device alternately causes a slide change and the triggering of a digital camera.
You need your own slide projector. On a german website you find a description for the modification. Never mind the language, the pictures show enough and Google Translate can translate the text well if needed:
https://www.photoinfos.com/Fotolabor-digital/Dias-2-Projektor-modifizieren-z...n-von-Dias.htm
There is more detailed information about the Filmolino Slidescan on the maker's website.
The device is not yet commercially available because they don't know if there is a demand for it. A minimum of 100 units must be ordered to be worth producing and shipping a first batch. If you are interested, please enter it on the linked page.
https://filmolino.com/slide-scan-en/
Alternatively you can try to build it yourself. On GitHub you'll find the instrcutions.
I have a prototype which works really well. The results depend on how well you align the slide projector and the camera with the lens to each other. Everything else is amazingly simple and you can digitize an entire slide magazine in minutes.
A connection to the smartphone can be established via WiFi in order to enter other values under 'Config'. This includes pauses between operations. After the slide change, my device pauses for 5 seconds before the camera is triggered. I do this to let tremors subside. Those using a flash for lighting can also use the pause function to give them time to recharge after a shot.
Early users should submit feedbacks to the developers, regarding for example whether the Filmolino Slidescan is compatible with your slide projector or not. I use a Leitz Pradovit R 150, which I could buy for €30 on eBay.
