I dont think my soviet paper will have such grading. They had one standard and one glass filter you could buy. There was no such choices. But probably those "grades" can be used with this paper. I'll just have to find their matching wavelengths, because that's how led's are "graded". (Just found out that grading is related to paper type not light colour..whoops).
This Thread seems to have a good explanation:
Beginner's Questions About Safelight
In short: it seems, like red light is good for all papers (Variable contrast and Graded - dont know what it means), but the amber is suitable only for Graded paper (sensitive to UV-Blue, VC - UV,Blue,Green). Amber is more pleasant to work under.
Now i just need to find what red is safe red. Here, a kodak PDF showing spectral transmission graphs and descriptions for various filters:
http://www.kodak.com/global/en/professional/support/techPubs/ti0845/ti0845.pdf
1,2 - RED, DARK RED: Starts cutoff at 700 nm, max density at 600nm.
RED - transmits up to 10% light. DARK RED ~7..8%.
Red led's usually produce light at 633, 660, 635 [nm] - last one being most common.
So i think it should be safe to use one.
Another thought is about perceived intensity. Since it has narrow spectrum, you need higher actual intensity for the light to look bright. But i believe it is the same for paper.
In attachment i've included picture of my paper packaging. There is only unreadable developing information and date of manufacture indicating that the paper is expired
A Kodak paper response curve confirming what's written in that thread.
A Dark Red filter transmittance graph.
