Originally posted by photolady Mine doesn't have any such setting. It has Preview and adjust film size, ie, 6x4.5, 6x6, etc and I've tried each of those settings and none of those settings changed anything. There is no setting to adjust format/aspect ratio. The only way to show the whole strip is take it out of "thumbnail" preview but then it scans the whole negative strip holder, but shows no film.
Greetings,
I was trying to describe it based on a weak memory - I just got my V500 on Christmas, so have not used it enough to remember it very well. So, I took some screen shots. Hopefully this will help:
I'm running version 3.24 of the software - maybe this makes a difference if you are not running the latest version:
In the main scanner panel, click on the "Configuration" button (notice that I am in Professional mode at the top - I've not even tried the other modes yet).
In the configuration window, select the film size tab and set it to the correct size.
In general, it should work with these settings. However, I did find one minor trick: If it does not "catch" the first negative, you may need to slide it down a little bit so that some clear space on the negative is visible to the scanner just before it hits the exposed part of the film. I had a couple of instances where the film did not frame properly in the preview window, and I found that I had the exposed part of the negative right up to the edge of the film holder so that no clear unexposed space was visible to the scanner. Sliding it down a couple of millimeters to expose the unexposed edge caused it to properly register the frames.
Alternatively, you can un-check the "thumbnail" box at the bottom of the main scanner panel window, in which case the preview window will not show the individual frames, but will show the whole film strip. You can use the marquee tool to select your picture. This would be a nice feature if you were using 120 film with a home-made pinhole camera, or other odd project which does not yield standard frame dimensions. Here is a screen shot of the no-thumbnail preview window to show you how it looks:
I hope this helps.
By the way, here is the result of this scan - my wife's cat Fritz in a showdown with a neighbor cat. This was taken with a Mamiya C220 TLR, Kodak B&W film, quite underexposed and a very thin negative. The scanner did an excellent job of pulling out the image. Picture taken in 1978, film processed by me in the darkroom at work.
I sure am having some fun with this nice V500 scanner!
-Joe-
