My Pentax DSLR makes a rattling noise - is it defective? Something is loose inside!
Posted By: Adam, 10-22-2010, 06:43 PM
Question: My Pentax DSLR camera is making a strange rattling noise when I move it around, as if something were loose inside. What's wrong? Is my camera defective?
Answer: No- there is absolutely nothing wrong with your camera! This noise is caused by the Pentax shake reduction system, which allows the sensor to move around slightly within the camera. When the camera is powered down, the sensor shifts around freely, as there's no electrical current present to keep it in place. Don't worry about this- it's perfectly normal, and is not a sign of any problems!
10-23-2010, 05:00 PM   #2
littledrawe's Avatar
idea?
Has anyone contacted pentax to see if they can put a HUGE disclaimer on the camera boxs that says something to the effect of; Don't worry about the clunking noise when your camera is off its perfectly normal. No matter how strong your urge is to start a thread at pentaxforums.com--DON'T DO IT!! I sense a little bit of tension in Adam's reply there, as well as, the other moderators when this question comes up!!
10-23-2010, 07:27 PM   #3
That should be added to the "Dear Pentax" thread- I think that it's a great idea. A caution or warning in the manual would be in order.
01-18-2013, 07:53 AM   #4
Would have saved returning my first K-7!
01-18-2013, 08:02 AM   #5
JinDesu's Avatar
I thought my k-x manual mentioned something about that. I'll have to double check. I know that I wasn't concerned with it when I first handled my camera, so I think I was informed about it somehow.
11-19-2019, 07:25 AM   #6
I have a rattling that has developed over the course of my ownership of a k50. It is a repeated and pronounced knocking that is both distracting and wasn't there previously. It appeared around the 10,000 shutter count mark. I'm outside of warranty and brought a different camera as a result. I regard it as a definite fault and it's important to distinguish between normal "slight" knocks and rattles to the repeated jerking and shaking of the sensor that definitely doesn't sound right on any camera.
camera, dslr, move, noise, pentax, pentax dslr, sensor
K-7: loose memory door? Normal or defective? AirSupply Pentax DSLR Discussion 3 03-05-2010 11:11 PM
Lens loose inside 50mm f1.4 waltzcore Pentax SLR Lens Discussion 4 09-24-2009 08:47 PM
K100D Super makes noise when I turn it on jct us101 Pentax DSLR Discussion 4 03-14-2009 12:46 PM
Loose Movement inside a new K100D Sandyw Pentax DSLR Discussion 12 05-26-2007 06:58 PM
If squeezing small pixels makes noise... Arpe Pentax DSLR Discussion 19 02-23-2007 08:29 PM
All times are GMT -7. The time now is 10:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
