Pentax Lens Disassembly Database
Posted By: Chaos_Realm, 03-22-2012, 05:04 PM
Hi all,
I have recently been on the hunt for dis-assembly guides for the purpose of dust removal etc. They seem to be turning up in various places across the forum, so I plan on creating a list of all the Pentax lens disassembly posts here. I will categorise each lens like they are in the 'lens database' and you should be able to see which lenses have a guide and which do not. If I come across multiple guides then I will list them all under that lens so there is coverage or alternative explanations. And hopefully with your help we will be able to put together a substantial resource for the DIYer's here, although I do realize some lenses will never have an owner brave enough to strip down themselves due to the shear value. I know this will take quite some time but I think it will be worth it. I have restricted time at this point but I want to get the ball rolling. So here is what we have:
NB: Currently this tread is only for Pentax K-Mount & M42 Screw-mount lenses. Maybe once this has developed a bit I might look at introducing other pentax Mounts and or third party lenses and permitting time (and success of this resource) a cleaning guide with tips on tools and techniques. I am trying not to bite off more than I can chew for the moment so we will just stick with lenses listed below.
Digital Era K-mount Lenses Film Era K-Mount Lenses
M42 Screw Mount Lenses
07-03-2017, 09:06 AM   #136
QuoteOriginally posted by timw4mail Quote
Fungus spot on rear group. Well, I'll probably just deal with it, but if it were simple to fix, I'd give it a shot.
put up a picture to verify that, if that is the case. It is easy to do.
07-03-2017, 09:40 AM   #137
timw4mail's Avatar
View of rear, with iris completely closed down. No spots visible in front of iris.
07-03-2017, 10:21 AM   #138
getting to the lens element is not a problem but, I THINK it is lens separation. Only way to rule it out is to open it up and clean the lens groups involved. It is in a Bad spot ,meaning it will impact the Image quality, So you have nothing to lose, try cleaning it. Start off using Zippo lighter fluid and finish off with alcohol. Also use Kim wipes. Remember to brush then blow then wipe. A friction wrench should be able to loosen it if not then a Lens Spanner wrench . Good Luck OH PS you should be able to remove the rear lens group without removing the Lens mount, hope you read this in time.
07-03-2017, 10:34 AM   #139
timw4mail's Avatar
QuoteOriginally posted by niceshot Quote
It's got all the fibers and texture that make me think fungus.
My fear is that taking it apart means I won't be able to get it back together. Using the lens a bit, I've seen some impressively sharp shots around F7-8, which lead me to believe that it doesn't influence image quality too much. My guess is that, at worst, it makes wider aperture shots more glowy.
If I were to attempt cleaning, I would very much like to have a parts diagram, at least. I'm sure the 1.7 lens is similar, but not quite the same.
07-03-2017, 10:43 AM   #140
SMC Pentax-A 50mm F1.2 Lens Photo - Pentax Lens Reviews & Lens Database here you are
07-03-2017, 10:36 PM   #141
Looks like fungus. With such a nice lens, I'd be inclined to send it to a pro. It looks easy, but they have the right tools. I've been in a few lenses, but I try to stick to the ones that don't cost a lot, in case I have problems. You'll lose the cost of the pro cleaing of that element just by marking up the spanner ring, it seems to me..
07-04-2017, 04:00 AM   #142
QuoteOriginally posted by Ranchu Quote
you can touch up lens spanner marks with magic marker, but it is best to use a friction wrench, Also this thread is for people who want to do it for themselves. Although I think that gentleman will probable heed your advice.
07-04-2017, 06:47 AM   #143
What do you use to clean of the fungus of the inside elements? Zippo fluids? 70% rubbing alcohol?
07-04-2017, 08:01 AM - 1 Like   #144
QuoteOriginally posted by Theov39 Quote
I personally use zippo to remove and loosen up every thing first ,then i finish up with 91 percent alcohol from cvs or where ever. You could use acetone then alcohol also but I like Zippo better. Also use Kim Wipes ,and after it drys use bulb blower to remove any lint. But you don't have to be acod about it. Remember less is more when cleaning, lest you could scratch it. Also remember to blow then brush then clean.
07-04-2017, 12:50 PM   #145
Thanks for that. I thought Zippo fluid might have been too strong and potentially damage the coating on the lens.
07-04-2017, 02:00 PM   #146
For fungus I use hydrogen peroxide, then Zippo lighter fluid, I don't blow off anything if I'm cleaning fungus until I've hit it with the peroxide. I finish with acetone. Just enough on a qtip so it evaporates almost immediately, you don't want acetone running into the seam between a retaining ring and the element. It will remove edge blacking, blacking on retaining rings, and melt plastic. niceshot, if I want to suggest the poster might want to take his lens to a pro, I'll do so.
08-11-2017, 07:41 PM   #147
Chaos_Realm's Avatar
I have heard that some of the older lenses repeated use can damage the coatings, but I have yet to see any ill effects. it probably depends on the particular coating on the lense. SMC has been fine so far.
08-11-2017, 10:30 PM   #148
I think that is a porky. Many materials may age, based on environmental effects on them in storage or in use. But the conditions of use of a lens are petty benign - the photographer must withstand the same conditions, and use is actually quite a short time. Use might expose them to conditions, such as dust and dirt, and the remedial actions might be the cause of deterioration.
Anyone have evidence of the claim of use induced deterioration?
08-12-2017, 11:19 AM   #149
QuoteOriginally posted by Chaos_Realm Quote
The coatings are made of Magnesium Fluoride, so quite resistant. And a lot of service manuals to Lens say to use petroleum ether and alcohol mixture. 70 - 30 mixture
08-19-2017, 07:28 PM   #150
QuoteOriginally posted by tim60 Quote
I have not seen any evidence and I use it myself, but I raised the point so that anyone reading can consider it and investigate for themselves. Given I know nothing of the chemical composition of coatings I wouldn't like someone to potentially destroy their lens because "someone on the internet told them to".
50mm, 85mm, bottom, cap, da, disassembly, element, f*300, f2.8, f3.5, f4, fa, filter, lens, lenses, macro, mate, password, pentax, pentax smc-m, post, rubber, schematics, site, smc, takumar, thanks, vanity, wire, youtube
Pentax-A 50mm 1:2 lens focussing ring problem/ disassembly help K7er Pentax SLR Lens Discussion 5 04-06-2013 04:27 AM
Suggestion Lens disassembly database Chaos_Realm Site Suggestions and Help 6 03-17-2012 12:38 AM
The Systematic Disassembly of a Pentax 50mm F/1.4 Lens LFLee Pentax SLR Lens Discussion 8 05-10-2011 10:58 AM
Lens disassembly & cleaning garethwebber Pentax SLR Lens Discussion 3 03-31-2011 12:59 PM
Bought my first pentax lens, this is the one in this database right? Lulerfly Pentax SLR Lens Discussion 24 11-06-2010 01:54 PM
All times are GMT -7. The time now is 10:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
