Here's some help if your K-7 needs AF adjustment (run out of AF fine tune range). Seems quite simple, there are same kind of screws in same locations as with the K10D (for which one can find service manual from the net,
Downloads).
There's one difference however; with K10D/K100D it's enough to just remove bottom plate, but in the K-7 the "third" screw (C adjusts front/back focus) is under the front cover (maybe they thought that fine tune is mostly enough..). Image from the RiceHigh's blog:
RiceHigh's Pentax Blog: Hardware Adjust a Pentax DSLR for the AF.
1. To remove bottom plate, just unscrew all visible screws. Two of them are under battery door.
2. To loosen the front cover, I would also recommend unscrewing the top cover (
neither cover needs to be completely removed). So all visible screws again, but there's one deep in the battery cavity, two behind the eyecup, two under the pop-up flash and one under the
left grip. Lens mount bayonet does
not need to be removed!
3. Once all screws are removed, the front cover should come out just by pulling it gently and pulling downwards slightly at the same time. The lens removal button and AF mode switch will come with it, so no worry about them.
Note: AF switch will have to be in the same setting/location as when the covers were still together, otherwise the front cover doesn't go back in place.
4. I adjusted the "C" screw about 45 degrees clockwise to fix back-focus. This translated to about 4-5 steps of AF fine-tune from the menu. So, no big adjustment needed, careful with it..
5. For the work, you'll need preferably a "JIS" standard screwdriver (almost the same as #00 Phillips) and a 1,5mm hex tool.
6. Careful with wires. See the pictures, my camera had the one blue wire scratched against the tripod mount (sharp metal edges), probably by a service man (I had the thumb wheel warranty replaced) or already in the factory..
