Modding Chinese (and other) tripod mounts to fit eg adaptall lenses
Posted By: marcusBMG, 10-06-2013, 07:35 AM
Modding cheap tripod mounts for other lenses
There are a range of very cheap, typically Chinese made, alloy tripod collars available. They are often described as being for Canon lenses eg a 66mm ID hinged one is described as for 70-200mm f4/Canon EF 300mm F4L/Canon EF 400mm F5.6L lenses.
UPDATE with a bit of browsing these are some of the ones available. ID = inside diameter; H/NH = hinged/not hinged, price approx in UK£ - UPDATE Feb '17 prices (UK) are higher now.
ID:H/NH material Described as for:price
65mm; 66mmH Alu Canon 70-200mm f4; EF 200mm; EF 300mm., EF 400mm ~ 5
68; 69mmH Alu Canon EF 100mm f2.8L macro IS7 - 10
68.5mm H abs Canon EF 70-200mm f/2.8L USM, Canon EF 70-200mm f/2.8L IS USM 5
70mmNH Alu Canon EF 100mm f2.8 IS USM10
71mm NH Alu Canon 100mm 2.8 micro ("old") 3 - 4
72mmH Alu Canon 180mm macro, 65mm macro11
77mm/78mmNH Alu Canon 70-200mm f2.8 5-10
81mm H Alu Canon EF 28-300mm f3.5-5.6 10
81/81.5mm H Alu Canon 70-300mmf4-5.6L IS USM 10-20
80mm/82mmNH Alu Nikon AFS 80-200mm 12
I have found these particularly useful to use, or adapt to use, with my Tamron adaptall lenses. As is the 66mm one is just about spot on to fit around the 01F TC (update most need a little packing). I find they are pretty solid items.
Pic 1 shows a 66mm one modded to fit a Tamron Adaptall 19AH 70-210mm. This lens zooms in moving out (unlike most lenses including most of the other tamron adaptall zooms) so the TM can be mounted in front of the aperture ring at the cost of only restricting the zoom action at the 70mm end. This also fits the 54B 300mm f5.6, the 52A 70-210mm and the 85-210mm. The other lens that benefits in the same way as 19AH is the 60-300mm 23A, which also zooms in moving out.
While it is perfectly OK to use eg cardboard, leather etc. as packing to make one of these TM's fit on a lens sufficiently well (I do so myself when the TM almost fits) I like to have a solid, stable fit. This is my relatively quick and easy way of modding eg the 66mm TM down to the ~ 62mm fit of the 23A.
NEED:
  1. LENS, MOUNT
  2. CLING FILM or alternative
  3. BODY FILLER/STOPPER/REPAIR PASTE eg "isopon" or similar (epoxy based pastes will probably work too but these styrene or polyester based ones are cheaper and easier to work with).
PROCEDURE
  1. Remove the stickyback felt from the mount. To peel it off in one piece and preserve the adhesive on it sufficiently I have usually resorted to warming it in hot water. Recently mounts have had double sided tape holding the felt on, in this case the DSS tape has normally ended up a bit trashed and discarded, and I have had to glue the felt back on or use new sticky back black velour/flocking.
  2. I also roughen/clean the interior surface of the mount once the felt is removed with sandpaper.
  3. Size up the mount around the lens and estimate how much filler. Typically something between large marble and golf ball size amount.
  4. IMPORTANT. don't forget to do this if you don't want the mount permanently attached to the lens. Wrap a layer of cling film around the lens where the mount is going to be used (if you have some familiarity with eg resins etc then yes waxing the lens barrel where it is going to be used as a mould is sufficient). A slight smear of paper glue eg pritt stick is good to keep the cling film in place (easily cleans off after with moistened tissue). UPDATE I am now using some heavy gauge polythene around the barrels - helps to offset the thickness of the felt and makes a smoother finish.
  5. Mix the filler with catalyst/hardener and smear evenly around the interior of the mount. Go easy on the hardener it's a nuisance if it goes off too quickly.
  6. Ease the mount into position and close it so that that the filler is moulded to the contour of the lens barrel. Align it square by eye. I find that it's best to close it tightly, then when the felt is stuck back on the slight decrease in ID is not a problem.
  7. Rather than letting the filler harden completely it is better to catch it while it is half hard or "green" - typically 5-30mins depending on how much/how old catalyst, ambient temp etc.. Then it is easy to ease the mount off the lens, peel off the cling film if used, and use a modelling knife to trim off all the excess.
  8. When the filler is fully hard, sand off any last excrescences and stick the felt back on, with a little glue if necessary. Voila!
PS you can also look at this article; describes making a mount from scratch.
10-09-2016, 01:58 PM   #16
Senior Moderator
Nass's Avatar
QuoteOriginally posted by marcusBMG Quote
Yes that's interesting Nass. Immediate project comes to mind: tripod mount for my takumar 200mm f3.5. Cheapest supply seems to be 50g multiples @ ~ £1.90ish/50g from HK/China (update: 500g for 13.99 off amazon). How much do you think that might need (this is a preset lens with aperture rings at the front so there is a 2.8cm space by the mount, 18.2cm circumference, ~ 58mm dia)? And do you think this stuff is soft enough and strong enough to mould around and hold a 3/8" to 1/4" TM adapter?
And finally have you ever had any problem with this stuff getting soft eg in direct sunlight?
it also occurs to me that this stuff could be a substitute for the polyester filler I have been using to mod the tripod mount rings.
FYI:
https://en.wikipedia.org/wiki/Polycaprolactone
I think 250g would cover it - no problems with it going soft at all. Don't know about the adapter but it's worked for everything I've needed. There's a bit of variation in quality of brands of this stuff; some are sticky when they're hot and others not. Less so is easier to work with.
10-15-2016, 07:10 AM   #17
For more ideas and solutions to fitting tripod mounts check out this thread by Lloydy on mflenses.com
Lens Tripod Collars. ( non standard )
adaptall, air, film, gasket, hull, lens, lenses, materials, mount, mounts, plastic, post, shape, stuff, surface, tamron, tripod
Camera Mounts for other lenses Raye Pentax SLR Lens Discussion 4 04-07-2012 08:56 AM
For Sale - Sold: Tamron Adaptall-2 28mm f/2.5 lens (02B); also PKA and PK mounts Nick Siebers Sold Items 6 02-27-2012 05:07 PM
Other MF lenses to fit 67? Herb Pentax Medium Format 5 03-17-2010 12:05 PM
Zeiss lenses with CPUs for Nikon other mounts to follow late 2010 PinarelloOnly Pentax SLR Lens Discussion 8 11-18-2009 01:36 PM
All times are GMT -7. The time now is 12:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
