Originally posted by carpents Micro tools is where you want to get lens repair stuff.
Thank you carpents, I will check them out.
Originally posted by dcshooter This will enable you to take the optical and aperture assembly of the helical, but you will still likely need a spanner and/or a rubber tool to take the groups out and get them broken down if necessary. A lens spanner is a tool that allows for the removal of notched retaining rings. .
I know what a lens spanner tool is and what it is used for. In researching them I observed that they come in a number of different designs and a price range anywhere from around the mid-teens to over $60. I was wondering if any one type might be better than another, or if the less expensive ones might work as well or are as durable as a more expensive model.
