Jupiter 21M Repair Thread
Posted By: Helios 1984, 08-01-2015, 12:19 PM
Hi guys,
I bought lens for 55.00$ on Ebay but wasn't aware that it was defective. I couldn't find any servicing guide for this particular lens so I had to go blind mode. I removed the back of the housing and quickly noticed the abnormal shape of the M/A lever, it was quite bent. I used plyers to unbend the A/M lever and reassembled the lens but it was still defective. The Helicoid could not focus beyond 4.5m. I disassembled the lens again and found out that the tip of the M/A lever would get stuck on the Stop Down Lever, and as I kept doing a backward focusing movement the M/A lever would slowly bend again.
Note: Only unscrew these if you need to remove the M/A lever. Also, the spring that hold the Auto Aperture Pin is fragile, it can easily break if the screw that holds it is fastened too tightly.
On the picture bellow, I already fixed the M/A Lever
Now back to the issues I had with my lens.
Issue No.1: The maximum aperture that I could use was f/11.
Cause: The M/A Lever wasn't positioned between the Stop down lever and the M/A Switch.
Issues No.2: The helicoid focus mechanism could not go beyond 4.5m.
Cause: The edge of this aluminum ring was not filed, it caused the Stop Down Lever to get stuck on it, thus preventing the helicoid from properly functioning.
When the M/A switch is set on Manual, the M/A Lever should push the Stop Down Lever all the way to the left so you can have access to all the Stops with the Aperture ring. Since the M/A Lever was bent, the Stop Down Lever was not properly positioned and only half the stops were available.
I filed the edge so it would not interfere anymore
Here's what the inside of your Jupiter-21M should look.
08-01-2015, 09:42 PM   #2
Canada_Rockies's Avatar
Good work. Interesting chase and detective novel almost.
02-11-2016, 02:42 PM   #3
Helios 1984's Avatar
I found these pictures on a German photography forum, same exact mechanical issues as I had with this lens.
Source: Phillipp from Digicamclub.de
aperture, bit, edge, focus, information, jupiter, lens, lever, meters, russian, stop
Repaired by Precision TooLoose Pentax DSLR Discussion 17 06-22-2015 08:45 AM
Concert Photos using Jupiter-21M 200/4 M42 fuseboxx Post Your Photos! 9 02-15-2010 05:20 AM
All times are GMT -7. The time now is 05:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
