Helios 44M-4 Modification - From Automatic only to fully Manual
Posted By: Helios 1984, 03-12-2016, 08:17 PM
Hi guys,
I came up with this easy modification to convert an Automatic Helios 44M-4 into a full manual lens, without the need of a flanged adapter. It is 100% non-destruction & reversible and won't cost you a dime.
Material needed:
- Exacto
- Heavy duty storage tape (I used StaplesŪ Heavy-Duty Clear View Premium-Grade 2.6mil, )
The rear barrel casing and the 4 screws.
Here you can see the Automatic Diaphragm lever, on which the Pin push to close the Aperture.
Cut a piece of tape of about 2cm x 3mm and wrap it around the bottom of the Pin.
Voila, you have a stopper, a manual lens and you didn't had to spend extra dollars on a flanged adapter.
Note: Be careful when you screw those lenses on your K mount body. The screws of the rear barrel casing are not flush with the casing, they are 1mm deeper and may cause the security pin of your body to get stuck in the gap.
Always press the lens release button, on your camera body, until the lens is fully screwed.
03-12-2016, 08:38 PM - 1 Like   #2
Otis Memorial Pentaxian
Thanks for sharing! This fix is similar to the one using a small plastic tube/sleeve to do the same thing. If you don't have a sleeve, use tape
adapter, helios, helios 44m-4 modification, lens, modification, pin, tape
What to buy: Helios 44-2 vs. Helios 44k4 vs. 44m? I am confused Lost Forever Pentax SLR Lens Discussion 16 06-03-2015 05:31 PM
Sibling Rivalry: Helios 44M vs. Helios 44M-4 stevebrot Pentax SLR Lens Discussion 36 08-03-2013 09:31 AM
Helios 44M-4 Auto to Manual Aperture Control Conversion... quattro Pentax SLR Lens Discussion 22 01-01-2013 10:22 AM
Why is Helios 44m-4 more expensive than 44m? iNicole Pentax SLR Lens Discussion 3 08-07-2012 07:48 PM
Helios 44M-4 vs 44M teartear Pentax SLR Lens Discussion 27 08-24-2011 03:25 AM
All times are GMT -7. The time now is 10:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
