Originally posted by leif_58
Hi all,
my Pentax Super-Multi-Coated Takumar 200mm f/4.0 No. 8178571 got the Auto-Manual switch stuck even if the pin is pressed. It feels like the pin being glues to it's position.
What should I try in which sequence ?
Thankyou in advance,
leif_85
Hi Lief,
As newbie, this just happened to me today, as I picked up a mint Super Multicoated Takumar 200 from a local Craigslister (Whoooee... my 1st Tak!)... while inspecting the Tak in the local Mickey D's parking lot, I was able to easily move the "Auto Manual" switch, but when I got home and looked at the aperature blades, the switch was locked in Auto and would not move..!! Luckily, I stumbled upon this thread, cuz just pushing the pin with my thumb was not working, but placing/screwing the mount cap back on pushes the pin in just a little further than my thumb could, and released the switch.
If you don't have the mount cap, you might be able to use a fingernail edge, small pin or end of a paper clip to push the pin in just a little bit further... hopefully, this will work for you too.
Now all I need is a proper M42 to K mount adaptor to use this beautiful lense..!!
