Originally posted by excanonfd Is the lens wide open when it's mounted on the camera (as it should be), or is it closed down to the minimum aperture opening?
It's closed, even if put on camera and move the e-dial, the display could be 2.8, 4, but the aperture stays closed
---------- Post added 09-12-2015 at 09:09 PM ----------
Originally posted by vonBaloney And is it actually in the 'AE' position? (You must use little black button on mount to get it in there.)
Yes, it is in AE position.
These are the steps I use:
1. set the lens to its widest aperture (2.8)
2. push the adapter on, when snugly start turning it, until the latch clicks in then spring out to its original position
3. set the 2 tabs to the slots (if they are not there yet)
4. set the lens to f22, push the AE-lock tab, now set to f32/AE, the lens is closed down (only a small hole formed by the aperture ring)
5. put the lens on camera
6. turn on the camera in Av mode, set the focal length,
------> the LCD may display as f2.8, or f4
------> but the VF is dark, all the time (while the lens in 'AE' mode) that it's hard to focus
------> and the aperture stays closed
Thanks for all the replies, maybe I'll bend the aperture limiting tabs in a little bit? Should the inner white part touch the lens wall? It might be possible a bad adapter, but I am trying to identify.
I guess my questions are:
1. when you set the lens to 'AE' mode, does the lens go wide open or stay closed?
2. when you put the lens on camera, turn on camera in Av mode, is the lens wide open or closed?
3. I can imagine that one can turn the e-dial, to, say f8, and the lens is still open, correct?
