Pentax-A 50mm f1.7 Aperture ring repair
Posted By: Just1MoreDave, 01-24-2010, 07:52 PM
The Pentax-A 50mm f1.7 is a very good lens except for one problem. A tiny part can break and jam the aperture ring at some place other than the A position. It often won't return to the A position, making the lens far less useful and valuable. The fix is not that hard and doesn't require special tools. It is probably better to read through this once before starting, then follow the instructions.
A clean workspace with good light is helpful. You may want a clear plastic bag to control a spring-loaded bearing. More on that later. A good quality Phillips #0 or #00 screwdriver is required to take off the mount. Tweezers, a small dab of lithium grease and a small flat-bladed screwdriver are optional.
I have heard that the mount screws have slots for a slightly different screwdriver head, but Phillips will work OK with proper technique - make sure you have good contact with the slot and apply even pressure. With the lens face-down on the work surface, remove all five screws. Grab onto the bayonet lugs and lift off the mount. You'll see this:
At this point, a lot of things are loose - the mount was holding everything together. The first thing you can do is lift off the stamped steel ring around the rear element. It links the aperture to the aperture ring. This photo will help you put it back in the right place.
Next, there's a thing on the left side of the photo marked with a green arrow. Pentax calls it the "A-M Selecting Plate", part number 38305.X50801. It has two more associated parts, a tiny spring and a metal plate. This part is critical in telling your camera you've mounted a KA lens. You can slide it out now with the tweezers, or leave it for later. The main thing is, these three parts are important for maintaining the A position functions. A closer photo:
I think it's easiest to take all these off and reinstall them in the final stages, instead of worrying about them staying in place. Here is the part, its spring and contact:
OK, now we'll talk about the second part that you don't want to lose. There's a 1.5mm ball bearing that makes the clicks between aperture settings. A spring is pushing it outward against the aperture ring, so when you remove the aperture ring, this bearing will launch into space. The bearing is just to the right of the off-white bump. In this photo, it is perched on its little spring:
If you have the lens in a plastic bag, when you slide the aperture ring off, the bearing will end up in the bag. I can usually just orient the lens so the bump is in my left palm, slide the ring off with my right, and the bearing is in my hand. This probably only works because I have spare bearings, so losing one is no big deal for me. The spring can also get lost when you're not looking at it, but it usually stays hidden in its hole. The aperture ring has the small black button in it too; keep track of that.
With the aperture ring off, you now have access to the problem. You probably see something like this:
And you have another tiny part falling out, one of those flat steel springs. Pentax put these springs on with a plastic weld, which doesn't last forever. (In their defense, they may not have expected people to be using these lenses 25 years later.) You can fix the spring in several ways. Epoxy glue is one solution. Pentax uses screws on almost all other lenses, if you have some very small screws. Screw heads or epoxy should not stick out at all, because the aperture ring has to slide by them. Here is a successful screw repair:
It's a good time to clean the aperture ring of any dirt, and remove other grit or dirt you see. One more photo to show you the little v-grooves that mark each click-stop for the aperture:
Now all you have to do is reassembly. This can be challenging because of all the tiny unsecured parts moving around. I use a small amount of lithium grease to relube the aperture ring. I also use a bit to stick the A button in place, and stick the ball bearing to its spring on the lens. I hold the lens sideways and orient the ball bearing so it's at the top and not falling off. I hold the aperture ring so the numbers are going the right way and the v-grooves are lined up with the ball bearing.
Then I slide the opposite side of the aperture ring onto the lens first. I keep sliding it on until it runs into the first (lower) flat spring, then use a small flat-blade screwdriver to tuck that flat spring under the ring. Then I slide the ring on a bit more until it's up against the bearing. I use the flat-blade screwdriver to shove the bearing down and slide the ring over it. Then the upper flat spring gets tucked under the ring and the hard part is done. You should be able to move the aperture ring and feel click-stops, and the button to select the A position should work correctly. Set the ring to the A position for the next step.
Next, reinstall the parts for the A contact. The contact plate goes in first. It has a hook that goes over the outer rim. I use a bit of grease to stick this in place too. It should be in this position, except of course your aperture ring is installed now:
Then just slide the "A-M Selecting Plate" into its slot. The stamped steel plate goes on next, flat side up. Use the first photo to install it; the tab in the aperture ring fits into the slot (red arrow). Line the mount up so the aperture lever will fit through its slot and the A contact will fit into its hole, then put that into place. Reinstall the five screws.
Check your work by mounting the lens on your DSLR. Set the aperture ring to A and see if the camera will recognize the aperture setting. Use the DOF preview to see if the lens stops down to the selected aperture, then change the aperture with the wheel and stop down again. (Exact controls to do this will vary with different camera models.) Then go use your repaired lens.
02-13-2019, 10:18 AM - 1 Like   #61
Not a Number's Avatar
QuoteOriginally posted by limestonecowboy Quote
Got a 1000 for 5 Quid, should be here shortly. Anyone need 900 ball bearings?
A thousand? The have them listed from anywhere from 10 pieces to a 1000 all around $3-10 USD on eBay US. You could always sell them them in lots of 10 or so for a pound with free shipping in the UK/EU to people who lost the bearing and end up making some money
02-14-2019, 12:20 AM   #62
I'd like a few, lets say 15 or so.
Shipping to Switzerland in an envelope?
02-14-2019, 03:56 PM   #63
limestonecowboy's Avatar
I went for a very cheap option. I'll look at stainless steel ones when I haven't been drinking wine! I'll give it a try at 0.5 pence per lens.
07-08-2019, 04:00 PM   #64
What is the purpose of those plastic welded springs? Something to do with the A button?
My 50mm wont go beyond f/8 suddenly, is it the metal leaf jamming up inside? After a few goes I managed to get it across to the A position where it will stay for now
07-08-2019, 05:49 PM   #65
QuoteOriginally posted by ekip Quote
The springs push out the button and are also what allows or stops the ring to move. That's why it is difficult to move the ring in and out of the "A" position as well as having the parts floating around making it hard to turn the ring overall.
07-09-2019, 12:30 AM   #66
Years ago Pentax decided to go from metal welds to plastic welds, taking the cheapy way out. Over time the welds failed and popped off leaving the tension bar free to jam
up the works when moving the aperture ring. If you do have the ring set to A position it is more cost effective to leave it there and live with it. I know from experience that it is
better to leave well enough alone. It is too bad because they really are excellent lenses that produce some wonderful images.
thanks,
TT
09-30-2019, 01:58 PM   #67
I've just performed a repair on my 50mm A.
The spring looked undamaged and flat so I epoxy'd it but it sits up higher than the other one. I could have tilted it but the mating surface wouldnt have been in full contact. I left in the old plastic weld as a peg and could see some old squeeze-out underneath it.
There's also some wear marks on the internal aperture ring (bottom centre)
Going to give it some time to set before I see what happens, in the mean time my 24mm 2.8/M has a rough focus ring which sometimes binds...
12-26-2019, 07:13 AM   #68
Chris_K's Avatar
Thanks for a great tutorial. I have just finished a repair on my A-50/1.7. Initially, I wanted to use screws but the smallest size I have is 2x6 mm which is too big. I used epoxy instead and it works great! The biggest challenge was to reassemble everything (took me 50% of the time and I almost lost the little bearing ball) but it works!
Thanks once again, cheers!
03-01-2020, 11:12 AM   #69
murrelet's Avatar
Super helpful. Just fixed an A 50 F1.7 and saved it from a junk pile.
03-04-2020, 03:31 AM - 5 Likes   #70
MVK
Lost spring, no worries
Just in case you lose the little spring while repairing, like I did, don't worry. Here is what I did while repairing my Pentax- A 50mm f 1.4 lens....
Got a spring pin of watch strap from local watch repair shop. Cut it at one end. Removed inside spring and cut it to required length. Please don't keep the length of spring too long. Please see the attached photos. My photo shows a rather long length of spring. It should be very short. Its function is to put slight pressure on ball head to make contact with camera body so that camera can recognize it as an A type or auto aperture type lens.
In worst case you can completely eliminate this part and your lens will become M or manual lens.
Hope this helps to someone. Good Luck.
11-28-2020, 10:43 PM   #71
Great tutorial.
04-19-2021, 08:16 AM   #72
Andrea K's Avatar
Wow! I have an smc-A 50mm f/1,7 without the ball bearing, now I figured out how to repair it. Thanks
09-01-2021, 01:07 PM   #73
titrisol's Avatar
Location: In the most populated state... state of denial
This fix also works on the SMC-A 28mm f/2.8
I got one for the cost of shipping since it was "broken"
It worked in A mode, but the diaphragm ring was almost impossible to move
09-01-2021, 02:23 PM - 1 Like   #74
reh321's Avatar
QuoteOriginally posted by titrisol Quote
I have an “A” 50mm f/1.7 that was kitted with my “Super Program” in 1983.
I didn’t realize how sharp it really is until I used it with my K-30,
but now it won’t focus to infinity. I believe the lubrication is dry.
Although I am fond of it - dating to the dozen years when it was my primary lens -
I have little incentive to take it apart, since I have something like five 50mm lenses,
including an 8 element Takumar, and frankly I hardly ever use one, since I typically
use shorter focal lengths. I have only “APS-C” cameras, and I typically use mostly use wider views.
Added: I’m writing mainly in tribute to that lens - it was a ‘good one’.
05-15-2023, 07:31 AM   #75
QuoteOriginally posted by MVK Quote
Thanks willdmo. I will be more careful. I also need to do similar surgery on my A 50mm 1.7
Came across two wonderful videos on you tube posting links below
Pentax-A SMC 50mm f2 Disassembly - YouTube
---------- Post added 12-09-15 at 08:33 AM ----------
Pentax-M 50mm F2.0 repair
Found following link on you tube. Hope it helps
SMC Pentax-M 50mm f2 Lens Disassembly - YouTube
Re: A / M plate/spring assembly, which is by far the trickiest and most frustrating part of the A lens repair/rebuild.
When I repaired the aperture ring parts (used epoxy, good results), I did not note the proper orientation of the A-M assembly's bottom plate (thin tiny metal piece) upon removing the back plate of the lens. So thank you to for posting the superb photo tutorial. Note that on this link to a YouTube video about A lens repair, there may be either a variation in, or perhaps an incorrect way, that the assembly was positioned in that video. Looks like the bottom plate's little tang is inserted downward into the aperture ring area in the video tutorial, rather than upward in the photos posted above. I tried both, but had difficulty with the YouTube video method, and chose to follow the photos. The repair seems to have worked - A mode and apertures are indeed functional. The Youtube repair fellow seemed to have a hard time with getting the assembly into place - trying to secure it somehow, which may be an error. Rather, it's the reinstallation of the the back plate with 5 screws that actually secures it, I believe.
50mm, aperture, ball, contact, f2, lens, mount, pentax-m, photo, position, screwdriver, screws, slide, smc, tube, youtube
Pentax M 50mm f1.7 aperture ring kbryant Pentax SLR Lens Discussion 1 03-25-2010 10:38 AM
M 50mm/1.7 - aperture ring stuck jzietman Pentax SLR Lens Discussion 12 12-21-2009 12:59 PM
Problem with stuck aperture ring on Pentax KA 50mm f/1.7 jhaji Pentax SLR Lens Discussion 8 08-15-2009 04:10 PM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
Aperture ring on lenses for Pentax? Duh_Vinci Pentax SLR Lens Discussion 5 12-06-2006 09:24 PM
All times are GMT -7. The time now is 01:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
