10-15-2010, 09:27 PM   #1
K5 vs KX
Hiya all, my first post. Just upgraded my KX to a K5 and thought I would post some comparisions. I know that some see it as a huge upgrade. While I would agree that high ISO IQ is much better than a K7, high ISO IQ seems just a little better than a KX IMHO. However, the camera is overall a large upgrade in usability, especially the focus speed.
Do note that the colors on the K5 and KX shots differ. Has to do with the auto white balance diferences between the two cameras and my lighting situation, which is florescent lighting and some light coming through a window as well.
K5-800
KX-800
K5-1600
KX-1600
K5-3200
KX-3200
K5-6400
KX-6400
K5-12800
KX-12800
Some Pixel Peeping
K5vsKX ISO 800
K5vsKX ISO 6400
Last edited by tsammyc; 10-16-2010 at 03:14 AM. Reason: accidentally swapped K5-6400 with K5-12800
10-15-2010, 10:50 PM   #2
Ciao a giudicare da quello che vedo sembrerebbe che il kx regge bene il confronto con gli alti iso con il K5 o sbaglio?
Te lo chiedo perchè sarei interessato all'acquisto di un K5 o un KR in sostituzione di un KX ma se la differenza nelle immagine prodotte è questa preferisco restare con la KX per un altro anno.
Ciao.
10-15-2010, 11:34 PM   #3
Thanks for this, this is exactly what the doctor ordered.
Which has truer colours or more accurate WB? And was this in full manual mode? The exposure looks rather different!
In all honesty they are pretty close but the K-x shots look better to me. However if the K-5 is under exposed compared to the k-x, as it looks like it is, its not exactly apples to apples.
10-16-2010, 12:01 AM   #4
Yay K-x! Go K-x!
However you may need to test under a range of lighting conditions to fully test them both, especially low-light. Low light is the real stress test of a sensor. The RAW software you use can also make a HUGE difference to how high-ISO output renders.
Having said all that, the K-5 looks excellent.
10-16-2010, 02:14 AM   #5
Fogel70's Avatar
To me it looks like iso6400 and iso12800 samples from K-5 has been mixed.
At least it looks strange that iso6400 from K-5 has more noise than iso12800. And that K-x has less noise at iso6400, but K-5 has less noise at iso12800.
10-16-2010, 02:22 AM   #6
JohnBee's Avatar
I find it rather confusing that the ISO6400 sample has more noise than the ISO12800 sample?
You sure you didn't confuse the numbers?
10-16-2010, 02:23 AM   #7
LeeRunge's Avatar
Thank you for posting these it gives us a known camera to compare. Any chance you could take a few in a dark room and compare the 3200's and up.
10-16-2010, 02:36 AM   #8
Steelski's Avatar
It probably helps the K-x that the exposure is about a stop overexposed. It is more like a 12800 exposure vs 6400 exposure. Also there is more DR in the K-5 shot if exposure is the same.
10-16-2010, 02:39 AM   #9
raz
QuoteOriginally posted by JohnBee Quote
that was my impression too
10-16-2010, 03:16 AM   #10
Hi all, in my haste, I accidentally swapped the K5 ISO 6400 with the ISO 12800. Its fixed now. Apologies
10-16-2010, 03:23 AM   #11
JohnBee's Avatar
QuoteOriginally posted by tsammyc Quote
Phew!
Thanks for clarifying that, makes plenty of sense now
Also... what settings did you choose with the K-5 in terms of NR for these tests?
Have you thought about match the Kx grain through onboard NR adjustements?
There are so many variables with the K-5 it seems that carrying out comprehensive testing seems very extensive.
Having said that, I'm happy to have your contributions and I hope to see more!
10-16-2010, 04:51 AM   #12
why not leave EXIF info? thanks anyway for sharing the pics.
10-16-2010, 05:31 AM   #13
Looks like the K-x, K-r and K-5 are going to end up about the same. I wonder who will end up the high ISO noise champ among the three when all is said and done
10-16-2010, 06:02 AM   #14
Thanks for sharing these. Wondering whey the very noticable exposure differences, though. KX looks overexposed compared to K5.
10-16-2010, 06:40 AM   #15
Except for a better AF and a better body I don't need to change my K-x ?
camera, dslr, iq, iso, k-5, k-5 ii, k-5 iis, k5, k5 vs, kx, pentax k-5
All times are GMT -7. The time now is 05:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
